whats going on need help?
iight got ls-v setup got all vtec parts only problem is when the car is hot n really hot days the car is giving me trouble starting, and when it does start it takes a while ta pick up and run normal its starts to idle at a low rpm like 200 and then it jumps ta normal also car would run and out of no where it would cut off and take a while ta start back what could this be i just add a nwe fuel pump new spark plugs and wires checked distrubtor checked main relay and everthing is good..i have a fully build head do i have ta tune it? other then starting problem the car runs fine.
could it be my fuel relay thats going bad is there a way ta check it and were is it located?
Modified by vtec-gorilla at 4:08 PM 7/20/2006
airjordan604
Jul 3, 2009 12:24 AM
plantmylotus
10
Oct 14, 2008 10:49 AM
