96 'lude obd2 f22 to obd1 h22 swap questions
Old Jul 19, 2006 | 07:13 PM
drummer0488's Avatar
Default 96 'lude obd2 f22 to obd1 h22 swap questions
Hello, I'm new to the forum and have a few questions about my swap. I have a 96 prelude with the obd2 sohc f22. I want to swap an obd1 h22 into it and need some info. I plan on using my f22 harness, a p13 obd1 ecu, along with my f22 tranny and flywheel.
1. Can I use a h22 power steering pump and line and bend it at the lower part like accord folks can?
2. How many plugs will I have to change on my obd2 harness? I know I need an adapter harness at the ecu, I will have to wire up the vtec, and (correct me If Im wrong) I have to wire the crank angle sensor into the distributer and address the internal external coil issues.
3. Can someone link me to a page that has in depth wiring how to's for this setup?
4. I can use my f22 a/c compressor and bracket? Correct?
5. I need to extend the fuel line or use my f22 fuel rail? Correct?
6. Do I need a different passenger side motor mount like accord folks or are all my mounts ok?
7. Does my f22 harness have a wire for the IAB? I read somewhere you can just run a vacum line straight to the Intake manifold? Correct?
That should clear up any grey area I have about this swap. Dont be afraid to flame me if all this info is somwhere else, but i have looked high and low for this sort of swap info including bought the "ultimate h22 swap guide" and a "honda swaps" book. I understand this swap is similair to the accord swap so ive been trying to read up on that. If someone could confirm the questions I listed or link me to some info that will help me I would be very appreciative.
Thanks to all of you who help, Grant
Old Jul 20, 2006 | 12:55 PM
Default Re: 96 'lude obd2 f22 to obd1 h22 swap questions (drummer0488)
Bump, Help PLease!!
Old Jul 21, 2006 | 05:32 PM
Bump, Someone?
Old Jan 26, 2009 | 05:14 AM
piper180's Avatar
I have a spark problem after doing tha same swap. I am waiting for someone to answer the same question
Mr_Wiggles
Aug 3, 2014 11:32 PM
b17itr
Sep 7, 2009 09:43 AM
zoomspeed05
Feb 19, 2006 11:04 PM
