how do you remove the crank timming gear
like it says how do you remove the crank timming gear off a b16?
its the gear right under the belt tensioner.
Modified by DC4 Rasta at 8:03 PM 7/19/2006
you need this tool and a lot of man power.
http://www.amazon.com/gp/produ...28013
thats the cheapest i've seen it for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Darren- »</TD></TR><TR><TD CLASS="quote">you need this tool and a lot of man power.
thats the cheapest i've seen it for.</TD></TR></TABLE>
impact wrench will get that off in an instant. If you want to try yourself, put the car in gear and have someone hit the brakes.....it will lock up the engine and you can try to break it off with a ractchet or wrench, but remember it's held onto at over 125ft/lbs so tools can break pretty easily.
Modified by adseguy at 6:02 PM 7/20/2006
i just wanted to let everyone know that its not the crank pulley im talking about. its called the timming gear or the harmonic balancer which actually balances the crank to reduce vibrations in the block. its located inbetween the the crank pulley and the oilpump. the timming belt goes around this.
the.hamburglar
20
Nov 16, 2005 01:49 PM
