Lucas Oil Stabilizer, Is it any good?????
Old Jul 19, 2006 | 06:35 PM
Si_chRis's Avatar
Default Lucas Oil Stabilizer, Is it any good?????
Well, i have only heard good things about Lucas Oil Stabilizer and i was wondering if any of you guys use it. Im losing a half qt of oil every 1-1.5 weeks. I have a 2000 si with the b16a2 72kmi. I use mobil 1 full synthetic W/ JDM hamp oil filter. I rarely hit VTEC only once or twice a week or never. My valves aren't bent and my seals are good cuz my compression is good across the board 200,200,195,190. I replaced, wires, plugs, cap, rotor, timing belt, all belts, and checked everything. Power is consistent but oil goes low over a wekks period id say from the top oil dot toa little over the first dot. I do let my oil settle. I was wondering if Lucas oil stabilizer will help my problem.
Old Jul 19, 2006 | 06:46 PM
Si_chRis's Avatar
Default Re: Lucas Oil Stabilizer, Is it any good????? (JSpeK_EM1)
anybody???
SOHC4life 96's Avatar
No. Someone did some study on it and it actually causes the oil to get bubbles in it. I don't remember all the details, do a search and you'll find it eventually.
Edit: after reading your entire post, you have a serious problem that won't be fixed by some magic bottle juice. If you're sure you're valve seals are good, then I would put money on the fact that your rings are bad. Lossing that much oil that fast is no bueno.
Old Jul 19, 2006 | 07:28 PM
Crx Jimmy's Avatar
its junk try some agip synthetic 10w60 good stuff If you really want to find an engine treatment thats good, get one with molybdenum (moly) it can have some benefits
Old Jul 19, 2006 | 08:39 PM
hitvtecgetloud09's Avatar
Default Re: Lucas Oil Stabilizer, Is it any good????? (Crx Jimmy)
use motul
Old Jul 20, 2006 | 03:58 AM
mikeycivic's Avatar
Default Re: Lucas Oil Stabilizer, Is it any good????? (hitvtecgetloud09)
no the rings are not bad, the b16 burn **** load of oil. I have the same problem and actually did a post on it and everyone said its normal to go through it in the b16 especially with synthetic oil. I was at like 3500 -4000 for an oil change couple weeks ago and only got 1 1/2 qts oil out my car. I am trying the royal purple 10w30 now and check it regularly. I am not blowing it out either because bumper is clean and no smoke out the back. I have 63000 on my Em1 and I think its just normal.
Old Jul 20, 2006 | 06:55 AM
dpkelly's Avatar
Default Re: Lucas Oil Stabilizer, Is it any good????? (mikeycivic)
Synthetic oil will harden all your oil seals (especially valve stem seals). I'd switch back to dino oil. I get better engine performance with Castrol. To see the study, go to bobistheoilguy.com. In fact it's here:
http://www.bobistheoilguy.com/...s.htm
Old Jul 20, 2006 | 07:33 PM
Si_chRis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">no the rings are not bad, the b16 burn **** load of oil. I have the same problem and actually did a post on it and everyone said its normal to go through it in the b16 especially with synthetic oil. I was at like 3500 -4000 for an oil change couple weeks ago and only got 1 1/2 qts oil out my car. I am trying the royal purple 10w30 now and check it regularly. I am not blowing it out either because bumper is clean and no smoke out the back. I have 63000 on my Em1 and I think its just normal.</TD></TR></TABLE>
well,i use the 5w30 mobil 1, should i switch to 10w30???
Old Jul 20, 2006 | 07:42 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpeK_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">well,i use the 5w30 mobil 1, should i switch to 10w30???</TD></TR></TABLE>
That won't make any difference. 5w30 and 10w30 are the same viscosity when hot. You could try 10w40, or you could switch to conventional oil which should burn off slower than the synthetic. Just make sure to check the sump frequently and keep it topped off.
How much oil are you losing, mileage-wise? X amount per unit time is not a good figure to compare because we don't know how many miles you are driving in that time period.
Old Jul 21, 2006 | 05:12 PM
Si_chRis's Avatar
Default Re: Lucas Oil Stabilizer, Is it any good????? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
How much oil are you losing, mileage-wise? X amount per unit time is not a good figure to compare because we don't know how many miles you are driving in that time period.</TD></TR></TABLE>
I dunno, mayb about 300-400 mi for every half qt. Like i don't lose much, i just re fill my oil till it reaches the second dotted line. It usually drops to around the first dot, then when it all settles, it just goes slightly over the first dot, then when i add a half qt, its almost to the second dot afteri drive around and let it settle till next morning
Old Jul 21, 2006 | 05:17 PM
5lugSlug's Avatar
additives =
Old Jul 21, 2006 | 08:16 PM
Bondeedo's Avatar
I remember hearing my boss tellin me about synthetic oil that when you put it in engines with higher mileage the engine burns oil quicker because the engine is like already broke in(sorry but don't remember the correct term that he used). Wouldn't gettin it port and polished help is stop burning oil, i heard its like makin the engine brand new.
Old Mar 3, 2016 | 08:00 PM
Tha Don Wave's Avatar
You said you use synthetic. That's the problem right there. Use conventional. I use valvoline 10w30 for my Jdm h22
Old Mar 3, 2016 | 08:01 PM
hondur's Avatar
Dur Da Dur
5 Year Member
10 yr old thread.
Anyway, the stuff is pretty good at swelling seals and gaskets to slow down leaks.
Tip14
Oct 14, 2007 01:10 PM
ac_attak
Jun 19, 2006 03:52 PM
matix
Apr 18, 2004 09:32 AM
RacerXintegra2k
Sep 12, 2002 11:34 PM
jonnyR
Jul 30, 2001 11:33 PM
