air intake
I got my new short ram and hooked everything up.. except the small thing that sticks off of it.. and i didn't do anything to a vaccum line. What is the little nipple thing for? And what am i supposed to do with the vaccum line?
what engine?
on the f22a1 the intake has 1 vacuum line that goes to the intake manifold, it would connect to a spot right next to the TB/coupler
the other one (its bigger) goes to the valve cover breather tube.
the breather is the one right above that round black thing on my intake.
whats he caping off?
and this i the thing im talking about
what is he pointing to? I have the the same intake but i have no idea where the hose he connected to it came from.
Thanks for the help
picture of your intake and what hose you are talking about might help.
i know i have a 93, but that little vacuum hose on mine, i just took the fitting for it from my old intake tube and put it on my new intake tube.
basically, just pull it out, drill a small hole in your coupler and force it through, it will seal nicely (if your hole is small enough) and it gives it a place to go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93cb7sedan »</TD></TR><TR><TD CLASS="quote">picture of your intake and what hose you are talking about might help.
Um.. it looks exactly like the one i posted. You see where his hand is.. and the little nipple and line hes pointing to and theres arrows pointing to it? Thats what im talking about
thanks.. where is the line located though? I didn't have to remove any lines or anything from the stock intake. Thats why i don't get why hes connecting that there, and if i don't do that, will it harm my car?
some people just take a piece of foam and stick it in the end of that line to make a filter for it and leave it loose.
i dont think its a good idea to leave a vacuum line of any sort unplugged
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">if you leave it loose won't you have a vaccum leak and the car won't run right? Because i didn't touch that and my car runs fine.</TD></TR></TABLE>
its probably some emissions bull **** hose.
mine didnt change either when i left it loose. but i still hooked it up.
tRaCeYoUiNcHaLk
Apr 25, 2007 08:47 PM
folta2169
Apr 25, 2005 08:36 PM
