Coilovers!!!!Help ASAP
Old Jul 19, 2006 | 03:18 PM
atg1290's Avatar
Default Coilovers!!!!Help ASAP
Ok well i got my coilovers installed finally after that pita lca bolt. Anyway i need to adjust them but for some reason the rear ones have no play so if i jack up the front the rear rises...And when i go up my drive way.. So i need to know what need to actually be adjusted the length of the shock assembly or soemthing else??
Thank you so much Honda-Tech!!
Old Jul 19, 2006 | 04:01 PM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re: Coilovers!!!!Help ASAP (atg1290)
can you give a better explaination. Are you saying you cant get the rear off the ground to adjust it?? Or that when you adjust the front to be higher, the rear gets higher too? Did you take the measuerments on each corner from the ground to the top of the outer wheel well?
Old Jul 19, 2006 | 05:32 PM
atg1290's Avatar
No..say i go up my drive way(Have to go doiagonal), the front is at a high point therefore the rear should have the play so it drops and touches the ground, but on my car when the front is on the high part of the curb, the rear goes into air..Hope that helps
Old Jul 19, 2006 | 05:37 PM
mike9571's Avatar
Default Re: (atg1290)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atg1290 &raquo;</TD></TR><TR><TD CLASS="quote">No..say i go up my drive way(Have to go doiagonal), the front is at a high point therefore the rear should have the play so it drops and touches the ground, but on my car when the front is on the high part of the curb, the rear goes into air..Hope that helps</TD></TR></TABLE>
SO your asking why it goes into the air? Im pretty sure that is common if you have very stiff suspension.
Old Jul 19, 2006 | 06:18 PM
atg1290's Avatar
Yes it is very stiff so im not that worried about it other than safety issues.
Integra414vteC
Suspension & Brakes
Mar 20, 2007 06:48 AM
atg1290
Suspension & Brakes
Aug 15, 2006 10:08 AM
PearlWhiteAccord
May 9, 2005 09:20 AM
typeeg
Honda Motorcycles
Nov 30, 2004 05:51 PM
mugenracer
Aug 26, 2003 09:51 PM
