B16 problems
Old Jul 19, 2006 | 03:02 PM
crxpwr1's Avatar
Default B16 problems
I have my engine today and It didnt come with a rear motor mount....where can get one? Just to let everyone know my tranny is a j1 and I have a pr3 ecu
How much slower is a b16 j1 then a B16 s1
Old Jul 19, 2006 | 03:43 PM
crxpwr1's Avatar
Default Re: B16 problems (crxpwr1)
Has any one ever moved the alternator to where the power steering sits
y-49's Avatar
i believe u can use the rear engine mount off a da someone correct me if i am wrong.
Old Jul 19, 2006 | 03:54 PM
slpnz6's Avatar
Default Re: (yellow rex)
you can use the rear crossmember bracket from a da... not sure about the mount itself
Old Jul 19, 2006 | 03:55 PM
civic16's Avatar
Default Re: (slpnz6)
mine didnt come with one either but if i can remember right it came from hasport.
Old Jul 19, 2006 | 03:56 PM
crxpwr1's Avatar
I have a rear crossmember bracket but I need the rear motor mount bracket
EDIT: Do you understand what I mean?
Modified by crxpwr1 at 5:11 PM 7/19/2006
Old Jul 19, 2006 | 04:11 PM
crxpwr1's Avatar
Default Re: (crxpwr1)
bump...can take pictures
Old Jul 19, 2006 | 06:22 PM
Crx Jimmy's Avatar
you need the L shaped braket that bolts to the tranny and over the rear mount on the crossmember, most peoples swaps dont have them use a 90-91 integra one, got mine from acura I think around $45
Old Jul 19, 2006 | 07:02 PM
crxpwr1's Avatar
Default Re: (Crx Jimmy)
alright thanks
Old Jul 19, 2006 | 07:15 PM
SiR Inspired ED7's Avatar
i love my j1 tranny almost the same specs as the type r tranny
Old Jul 19, 2006 | 07:20 PM
crxpwr1's Avatar
Default Re: B16 problems (SiR Inspired ED7)
nice sweet to here but mines only going to have a few bolt ons and be a DD for a while
Old Jul 19, 2006 | 08:43 PM
hondasniper's Avatar
You need a mount kit if those mounts didn't come off a CRX. If they did, then you can use your stock one and put it on the Right 2 holes (there are 4 holes in the rear crossmember). If the mounts came off an XSi dont try to work around it. There are some good ebay sellers that have good mounts. I bought mine on ebay and they are still holding strong. MAKE SURE THAT THE REAR MOUNT IS POSITIONED ON THE RIGHT 2 BOLT HOLES. The left half is for USDM while the Right half is for JDM. If you get some good mounts, it will use 3 bolt holes so you cant get it wrong. As far as the rear mount bracket, you can go on ebay to find that too or suck up ~$57 at Acura. Good luck.
Old Jul 20, 2006 | 05:04 AM
crxpwr1's Avatar
Default Re: (hondasniper)
k I dont know if you under stand I have my mounts got them from innovetive mounts( dont know how to spell it) but the engine bracket on the tranny will take a PIC today
Old Jul 20, 2006 | 07:35 AM
mikespike2's Avatar
You will need a mount kit no matter what, but you still need the rear braket from a DA to attach to the rear transmission mount.
I have one if you want to buy it.
RanCRX
Sep 7, 2012 07:21 AM
MitsukillinS2K
Mar 15, 2007 01:05 PM
GEIJIN
Oct 8, 2006 11:21 PM
crxpwr1
Jul 20, 2006 03:04 PM
paulzy
Apr 23, 2001 12:35 PM
