225/45/15 hoosiers on stock jdm 96 spec itr 6" wheels
i've read a bunch of posts about running 225 series tires on an ITR and I understand that on a USDM ITR these tires will rub in the rear without a 5mm spacer, but i wonder if that will be a problem on my JDM ITR since the track is different.
also what are the general pros and cons of running a 225 tire on a stock 6" wide wheel? I have heard people say "slop" and decreased turn in, but increased overall grip.
has anyone run 225 series tires on stock rims at all 4 corners for road racing?
well seing as how the 96 spec itr is 15" and you want to run a 16" tire id say it wont work
225 on a 6"wide wheel would be very very sloppy handling, but i dont think you can even get a 225 on a 6" wheel can you? good luck with that one
and the rubbing would eb a factor depending on how low you are and what the offset is, my buddys itr rubbed with stock rsx tires 205 55 16?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FullRaceHonda »</TD></TR><TR><TD CLASS="quote">well seing as how the 96 spec itr is 15" and you want to run a 16" tire id say it wont work
dammit, i meant 225/45/15
The R6 in 225/45-15 is approved by Hoosier only for rims that are 7.0-9.0 inches wide.
The 205/50-15 is approved for 6.0-8.0 inch rim widths.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">The R6 in 225/45-15 is approved by Hoosier only for rims that are 7.0-9.0 inches wide.
werd, thanks for the info. won't even try mounting them then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC »</TD></TR><TR><TD CLASS="quote">has anyone run 225 series tires on stock rims at all 4 corners for road racing?</TD></TR></TABLE>
Wai's race car when it was owned by Spoon ran a 225-45-16 Advan on their RG's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC »</TD></TR><TR><TD CLASS="quote">the title of my thread is misleading, i meant to say 225/45/15 tires not 16" tires</TD></TR></TABLE>
In that case, I run those on 15x7 wheels for autox.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC »</TD></TR><TR><TD CLASS="quote">i've read a bunch of posts about running 225 series tires on an ITR and I understand that on a USDM ITR these tires will rub in the rear without a 5mm spacer, but i wonder if that will be a problem on my JDM ITR since the track is different.
wait a second..... what makes you say the jdm itr has a different track?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">
96-97 spec JDM ITR has 4x114.3 hubs, with GSR sized rotors, and GSR calipers and pads. I have been told by others that it also has the same track as USDM non-ITR integras.
</TD></TR></TABLE>96-97 spec JDM ITR has 4x114.3 hubs, with GSR sized rotors, and GSR calipers and pads. I have been told by others that it also has the same track as USDM non-ITR integras.
yes, but you were comparing usdm itr's to jdm itr's.
i know of no such difference in dimension - track for track between the two.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">yes, but you were comparing usdm itr's to jdm itr's.
i know of no such difference in dimension - track for track between the two.</TD></TR></TABLE>
i think it was reid or someone that confirmed the difference in track for JDM 96 spec vs JDM 98 Spec. JDM 98 Spec = USDM (except for 36mm axles).
-T
-T
PeterVSays
34
Dec 19, 2013 03:19 PM
YumVTEC
Jun 22, 2006 03:35 AM
aklucsarits
Feb 12, 2005 10:54 AM
Cosworth
10
Mar 27, 2002 06:53 AM
