OT: dont wanna get skammed ecu experts needed
http://www.pgmfi.org/twiki/bin...ecode
the middle three digits will say p72 if it is a p72, and the second to last digit will be a 0 if it's a 5-speed, and a 5 if it's an auto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastbay92cx »</TD></TR><TR><TD CLASS="quote">http://www.pgmfi.org/twiki/bin...ecode
the middle three digits will say p72 if it is a p72, and the second to last digit will be a 0 if it's a 5-speed, and a 5 if it's an auto</TD></TR></TABLE>
no disrespect but i wouldnt trust the label code
the seller could have swapped ecu cases
at the same time an auto ecu can be converted to manual and vice versa
best way to check is to open the ecu itself and check for the auto lock tranny transistors
if the ecu has been worked on (converted) check to make sure RP18 (located just under the 29c256 socket area, or in the pic, bottom right corner) has a jumper wire in it or a "resistor type" package with a black line across it. as alot of ppl will get auto ecu;s and convert then to manual without removing the transitors due to laziness.
labeled in this pic jacked from pgmfi
ringgold
Sep 29, 2004 12:02 PM
