Noisy Throwout Bearing - Replace asap? Can it wait? Urgent?
Old Jul 19, 2006 | 11:43 AM
DJ Gurgla GSR's Avatar
Default Noisy Throwout Bearing - Replace asap? Can it wait? Urgent?
My throwout bearing is noisy (determined what it was through searching). Sounds like a chirping from the tranny. it instantly stops with any pressure on the clutch and i hear no clicking (so i don't think its the input shaft bearing)
anyway, its an ACT throwout bearing, with only 6k miles on it.
Over the winter, i'll be dropping the tranny, and installing an LSD. I'd rather not go through the hassle of the tranny removal twice if i can avoid it.
So how urgent is the replacement of the noisy throwout bearing? Could it fail or potentially break? Or just continue to make noise?
Any info appreciated. Thanks in advance...
Old Jul 19, 2006 | 11:54 AM
jdm_bones's Avatar
Default Re: Noisy Throwout Bearing - Replace asap? Can it wait? Urgent? (DJ Gurgla GSR)
I wouldn't chance it, you maybe able to still save that clutch...
Old Jul 19, 2006 | 12:18 PM
Default Re: Noisy Throwout Bearing - Replace asap? Can it wait? Urgent? (jdm_bones)
? what is your theory for why its damaging my clutch?
Old Jul 19, 2006 | 02:16 PM
sweetdill's Avatar
if your throwout bearing isn't spinning it's wearing the springs of your pressure plate.
do you get chatter as you let out the clutch?
Old Jul 20, 2006 | 05:17 AM
Default Re: Noisy Throwout Bearing - Replace asap? Can it wait? Urgent? (sweetdill)
i don't think i hear any chatter
how do you know its not spinning? is that what is causing the noise? i was thinking that it is spinning, just making the noise as it does
Old Jul 20, 2006 | 06:56 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Well lets see, the throw out bearing I had from a clutch kit,
One of the ears busted off, and then some how punctured a hole in the casing,
so my fluid eventually slowly leaked out, and No idea it was from the trans.
So a couple days later, along with 5th popping out, my trans locked up, pretty much died.
Possibly, if things break off of the t.bearing, you could fu<u></u>ck stuff up inside.
Old Jul 21, 2006 | 05:57 AM
Default Re: Noisy Throwout Bearing - Replace asap? Can it wait? Urgent? (FlatBlackTeg)
After researching some more, i'm learning this could be a bad slave cylinder? or the slave cylinder needs lube.
what do you think?
carlosd68
14
Jun 1, 2012 09:21 PM
Egreyes
Apr 15, 2009 05:05 AM
Baron55
Dec 19, 2006 06:25 PM
Aron Parsons
Mar 6, 2006 09:18 PM
jfrye
14
Apr 26, 2005 03:57 AM
