Which one is the relay for the ac?
Ok, so im guessing its the one on the drivers side. I unplugged the harness going into the relay and tested it with a test light. When i have the ac on, the top two are getting power but the bottom two arent. When i have the ac off, the same thing happens, the top two work but the bottom two dont work. Is this how it should be?
Top two get power, bottom two dont. Just making sure this is what it is supposed to be, before i buy a new relay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rgaray »</TD></TR><TR><TD CLASS="quote">Driver side is the relay. It could also be the clutch on the AC comp.</TD></TR></TABLE>
No, cus when i run a wire from pos terminal on battery, to the wire, the clutch kicks in. Im thinking it has to be the relay.
Anyone know if the relays at autozone, advanced auto parts are close to as good as the dealers? I know the dealer will probably be 2x as much.
my A/C relay went bad not too long ago. You should test the relay itself, not the harness. I can't tell you which one is the a/c because mine weren't mounted. One of them is for the fan and the other, a/c. So a way to check is to disconnect one and if the fan kicks on, then you found the a/c relay.
i got mine at http://www.autopartsauthority.com - it ran me about 40 bucks but shipping was quick.
frank316
17
Jun 20, 2011 03:44 PM
