1986 rim help?
i have a 1986 accord that i use for oval track racing. the rims that i have on it are 14" in diameter. i don't no the offset but i want 15" rims to fit a wider profile tire. i use used tires so it's hard to find 205's or 215's for a 14" rim. are there any rims on any other honda that has the same bolt patern (which i think is 4x114) and 15" in diameter. thanks.
Accords are by far the most numerous Honda/Acura cars with a 4x114.3 bolt pattern. Other models with that bolt pattern on 15-inch wheels include:
1992-1996 Honda Prelude
1995-1998 Acura TL
1997-1999 Acura CL
1992-1994 Acura Vigor
1986-1990 Acura Legend
1996-1998 Acura Legend
Try doing a search on Transwheel's website (click on "online retail catalog") for illustrations...
1995-1998 Acura TL
1997-1999 Acura CL
Oops! mrrlx is correct.
Of course, you can always measure it to be sure. (The 100 or 114.3 refers to the diameter of the bolt circle, measured at the center of the lug nuts. On a 4-bolt pattern, you can measure the distance between the centers of two opposite lug nuts on a wheel. It will be easy to tell whether it's 100 mm or 114.3 mm.)
If it's 4x100, there are lots of wheels with that pattern, since it's used by most Civics and most Integras.
dumaguetecity
Wheels
Jul 1, 2011 01:34 PM
GSRMatt
Acura TL, RL & ZDX
Jun 16, 2002 03:46 PM
pelotudo
Jan 5, 2002 01:25 PM
