Size Of Injectors in a 99 and up Prelude??
I thought they were 320cc? Or does the size matter on what type of model the motor is from. For example, a regular Vtec Prelude or an SH Prelude??
[Modified by King Si, 5:11 AM 4/22/2002]
[Modified by King Si, 5:12 AM 4/22/2002]
1997 and up are all 290cc high resistance. There is no difference between SH and base models.
OBD1 models with H22a1 have 320cc low resistance injectors.
Anyone know when they're going to fix the search?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MartGSR »</TD></TR><TR><TD CLASS="quote">Does that mean, that 99injectors prelude will not fit with my stock clip ? (i have a gsr 95 obd1) ?
thank you</TD></TR></TABLE>
thats what i want to know as well!
also do you know since the 95 H22a1 are 320cc................ the max stock honda ecu can control is 310cc from what i have reasearched. anything larger than you would need an AFC to get it to idle....correct?
The 92-95(96?) H22A injectors are rated at 310cc in the service manual. However, as several people pointed out, they flow closer to 340cc to 350cc in reality. They are peak and hold injectors.
The 97+ H22A injectors are rated at 290cc in the service manual. They are saturated injectors. I have never seen flow test result data from them, but I would wager that they also flow higher than they are rated, though probably not nearly as much as the earlier peak and hold injectors.
Andrew
Andrew
Padawan
Jun 25, 2011 11:31 PM
junya16
Oct 9, 2003 01:11 PM
stupidfast
Aug 20, 2003 01:46 AM
