n00b question about offset
never got the concept down on offset...
anyways...
on a 16 inch wheel can i run a 16x7 on a +40
or a 15 inch wheel can i run 15x7 on a +40
this will be on a slammed FIT...
thanks
-Fred
anyways...
thanks
-Fred
Offset is the distance between the wheel's center line and the inner wheel face (the surface that mates with the car's hub). A wheel with an offset of 0 would mate with the car's hub exactly at the left-to-right center of the wheel. Positive offset pushes the wheel face closer to the outside (moving the tire inward) while negative offset pushes the wheel face closer to the inside (moving the tire outward).
Go here for a wheel offset calculator: http://www.1010tires.com/WheelOffsetCalculator.asp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeR564 »</TD></TR><TR><TD CLASS="quote">thanks for the help...so will the 40+ work or will i have rubbing?</TD></TR></TABLE> u will NOT have rubbing use 195 size tire. clear all day long.
for aggesive offset run 16x7 +35 front and 16x8+35 will need to roll the rear! (rub forsure the rear)
Alexander
Mar 25, 2005 02:40 PM
