Looking for OBD II Compatible Test pipe, anyone know where to get one?
Save the flamming for later. I am looking for one just because I am sick of haivng Carsound cats. go bad on me. If I can find a test pipe like the Godspeed one I had before (never threw any type of check engine lights) I will probably end up switching to it.
As I said, Carsound
As I said, Carsound
i've had my godspeed test pipe for over a year and still no problems. but i did break 2 sets of bolts that connect the test pipe to the exhaust manifold.
Yeah, I might actually contact Dan; hell, I could probably get my own made; I know what flanges I need.
I really would just like a high flow cat. that works though. Maybe I should look in to other brands of cats.
Although I discontinued them a while back I still have a handful lying around. The last of the OBD-II's for the Hondas. Just let me know if you need one Onyx.
As I said, Carsound
As I said, Carsound
who else makes good high-flow cats? i guess i have something to look forward to when my carsound starts throwing CEL's at me...
*crosses fingers* maybe it won't happen, i'm installin mine in a couple of weeks
I will let you know.
It's comming off as soon as I get the chance so I can see if it is clogged.
I swear; if anything is actually visually wrong with this Carsound cat I will first gut the cat. and then I will go over to Carsound and gut them... j/k
I am most angry that it takes them so long to warrenty it. I mean ****, it's not like I can drive around without a cat. Last time I ended up just buying a new cat. and then I finally got refunded for it after about a month of carsound dragging their ***!
I switched to a testpipe a few montsh back becuase my carsound started throwing a cel,and i figured it wasnt worth it. I just recently i put my obd2 ecu back in, and i have driven my car for 800 miles with the testpipe and obd2 ecu. I have not yet gotten a cel light. I dont know why either.
but if you get caught without a cat...
that's my only fear. i hear fines can be upwards of 10k.. in california. this true??
Yeah, I mean most likely they would give you a fix it ticket.
I would tend to agree, driving around with a test pipe is a bad idea; however, it's the hassle (from my experience) of dealing with a cat. that people do it.
I will be contacting the place that sold me my converter on Monday and I will see what they say.
Jeg's is your friend. Much cheaper than the Carsound cat. All you will require is contained within --> http://itr-nc.com/pages/jdm_4.htm
[edit] Forgot to mention they are ~$50, plus $4 or so for an O2 bung [/edit]
Pat, who passed NC emissions testing with a Jeg's cat and Spec B's
[Modified by itr009, 12:02 AM 4/22/2002]
Godspeed test pipe should be good. If not, just run a high flow cat. Or you can just get an OBD I ecu, never have to worry about the 2nd O2 sensor again!!
Test pipes
J/K. You should check out Jegs at tell me what you think of their cat, heck it's only $50.
check http://www.testpipes.com also if you are worried about a ticket get a heat shield. if I cop looks with a mirror he probably wouldn't be able to tell it wasn't a cat.
For all you recommanding Jeg's Cat. it seems the closest they have to what you guys say to use is a 2.5" diameter, and 13.25 inch long. I know on http://itr-nc.com/pages/jdm_4.htm they say to use a 14" model. I tried searching for the part numbers listed and it says they are discontinued.
Any suggestions?
Any suggestions?
any of the domestic catalogs, http://www.carparts.com, http://www.wrenchead.com, http://www.summitracing.com they should all have some cats similar to the jegs one.
Drinker
