How hot does your valve cover get?
Old Jul 18, 2006 | 10:06 PM
vinuneuro's Avatar
Default How hot does your valve cover get?
After normal/lightly spirited driving I can't even touch my valve cover, it gets that hot; and it takes a loong time to cool down. When I had my 92 w/ the h23, it never seemed to get this way.Any of you experiencing this as well, or is something wrong? My coolant temp is always slightly below half-way.
Old Jul 18, 2006 | 10:08 PM
98vtec's Avatar
moderator emeritus
Default Re: How hot does your valve cover get? (vinuneuro)
its pretty hot.
Old Jul 18, 2006 | 10:17 PM
HybridBB6's Avatar
Default Re: How hot does your valve cover get? (98vtec)
Umm why would you want to touch your valvecover after a sprinted drive?
Old Jul 18, 2006 | 10:20 PM
98vtec's Avatar
moderator emeritus
Default Re: How hot does your valve cover get? (HybridBB6)
work on the car, check plugs, add oil........
Old Jul 18, 2006 | 10:41 PM
vinuneuro's Avatar
bingo. try doing something as simple as taking the oil cap off when that valve cover is simmering...you'll know what im talkin about..
Old Jul 19, 2006 | 04:45 AM
maks's Avatar
Mine gets ridiculously hot, but then again, so does my entire engine bay... I am surprised that you were surprised by this
Open your hood and let it cool for a while. It's better not add cold oil or unscrew anything while the engine is burning hot.
I will admit though, things aren't nearly as hot on the civic.
Old Jul 19, 2006 | 05:33 AM
Jagan'92's Avatar
do you have the heat shield still on the header?
I know once I took mine off temp went way up. But I have an h23 so it's still probably cooler than yours.
Old Jul 19, 2006 | 07:33 AM
petern101's Avatar
Default Re: How hot does your valve cover get? (Jagan'92)
yeah mines hot. i have an infrared pyrometer. maybe next time i should use it
i have to add my monthly oil intake (normal stuff for h22) and i like to do it at the gas station. and the mugen oil cap is freaking hot and leaning over pouring the oil is also hot.
Old Jul 19, 2006 | 07:49 AM
ninja 6's Avatar
Default Re: How hot does your valve cover get? (petern101)
mine is t3h h0t
Old Jul 19, 2006 | 08:16 AM
98TypeSH's Avatar
Default Re: How hot does your valve cover get? (fish stick)
If you need to work on the car, pop the hood and get a nice box fan on full blast and sit it on the radiator support and aim it in. Or just wait 3 hrs.
Old Jul 19, 2006 | 10:05 AM
FinallyGotMine's Avatar
i have a 93 vtec and it can get pretty hot since it is in the engine bay and is metal, keep in mind, but like dude said just make sure your oil is changed every 3k and check your oil level every week and it should be fine... no worries
high-revving engines will heat up a good amount
Old Jul 19, 2006 | 11:07 AM
Hawkze_2.3's Avatar
Hell, operating temp is + or - 200 degrees, so is it really any suprise that the VC is that hot?
ChrisHinds
Paint and Body
Aug 25, 2008 11:22 AM
IDVirii
Apr 28, 2008 03:21 PM
PhantomX
Jun 2, 2006 10:12 AM
frostcivic
Aug 15, 2004 05:47 AM
SlayANT
Jan 31, 2002 10:40 AM
