4th gen front side bumper light wiring relay problems.
my front bumper side light does not work... the light which stays constant and blinks.. i replaced the bulbs but still no light.. its not getting any power.. all fuses are good. i wanted to know if someone would help me out with a wiring diagram or at least let me know if theres a relay somewhere.
i have the same problem and aint too far from you, maybe we can troubleshoot this together cuz the only possibilties anybody on here will give us is a short in the wire which i doubt is the cause
i had the same problem n went to the local pick-a-part n got the relay n the fuse box...so i change the relay n stil the same thing so i change the fuse box that is inside the left side panel n them it worked....maybe u have the same problem?
