blower motor ????
did you check the fuse?
try removing the glove box first. after that's removed you should have access to the 4 pin wire harness on the front of the blower motor. Check for voltage and check the resistors. Blower motor is secured by 3 bolts. there's one more bolt below not pictured. remove the R evap housing bracket. i'm pretty sure the dash has to come out for removal. someone correct me if i'm wrong.
johnclaunch
Sep 8, 2004 10:59 AM
dingusjt
Nov 13, 2003 02:10 PM
VTECAcuraGSR
Apr 13, 2003 10:31 AM
free BUMP
