need help !!! back tire not straight
I need somebody's advise on this problem, well this happened 2 weeks ago i was driving on the highway at 50 or 60 mph when suddenly my back left lower control arm snaps in half. So now my back tire isn't straight it is tilted to the right a couple degrees . i changed all the part from that side of the tire, got a alignment twice and it is still tilted don't know what it can be? oh by the way i have a 95 accord 2dr ex please reply.....
where your trunk opens and closes near the winshield there should be a factory looking seam sealer covering factory welds.make sure both sides are identical.if theye not then it was hit in the back and they replaced the quater.
check under the car(with a jack) to make sure under the car where the spare would be isnt bent basically just search that side under and exterior for damage that was repaired.
phongcrv
May 16, 2016 06:43 AM
tortis
May 11, 2012 10:25 AM
