stroking a b16
wutz up ht. i was offered a stroker kit to make my b16 a 1.8 for 1600 including machine shop cost. what do you guys think is it worth it? and whats the largest you can stroke a b16? thx
well i would look more towards the bore of the block instead of the stroke. you could get a b16 sleeved to 84mm with a 89mm ls crankshaft and it will be 2.0L of displacement.
or you could get a b16 block sleeved to 84mm with a 95mm eagle crankshaft. yada yada.
i dont think that its worth it you arent gaining that much displacement for the money. like the previous poster said u can use other oem parts to stroke the motor. the main thing i would look into is a 84mm bore b16 you can find them all the time. that is where you will gain your torque from
so all i gotta do to get that 84mm bore is sleeve it? and i had asked the same guy thats selling me the stroker kit if i could put an ls crank in my block he said yes but i would need custom rods, he said that would get really expensive..is that true?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 »</TD></TR><TR><TD CLASS="quote">Word. Just buy a B18 short block. Better yet, just buy a B18C.</TD></TR></TABLE>i thought about that but id be spending double the money..i really wanned a b20 but i heard the sleeves are really weak. so since i have a b16 block already i was thinking about making my own b20...i think it'll cost about the same. id buy new pistons rods n sleeves for the b20, so i figuered id just do it to my b16.
BOOOOOOO crv blocks do have thiner sleeves but can handle most street aplications you can throw at them... I think someone said they've seen a crv with stock sleeves running at lik 13.4:1 comperrsion with no problems :S
stock b20 bottom ends are **** if your going crvtec but the sleeves from what ive gathered are alright AS LONG AS YOUR NOT BOOSTING, If your goin crvtec A vtec oil pump, water pump, arp rod bolts, head studs, and shot peened rods In my opinion is a must for reliability.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">Or you can buy a GSR crank for....300-400$ that will do the same thing. All you would need are bearings and rings...</TD></TR></TABLE>
He cant use the 1.8 gsr crank,,,but he could use the B17a gsr crank,and rods and make his b16 a 1.7 ,,but i dont really think its worth it in the end....Its just better,easier and cheaper to get a B18 block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Panda »</TD></TR><TR><TD CLASS="quote">BOOOOOOO crv blocks do have thiner sleeves but can handle most street aplications you can throw at them... I think someone said they've seen a crv with stock sleeves running at lik 13.4:1 comperrsion with no problems :S </TD></TR></TABLE>
That is not true,,,why do you people say B20's have thinner sleeves ? thats bullshit,,the sleeves are actually thicker then the other b-motors,,,,,but its the unisleeve design that makes the engine weaker ,,,,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">
so what do you guys recommend? i got the b16 block for free, my cusin went ls/vtec and gave it me...i dont got much money as im a full time student with a shitty job n this is a project car, i have a daily driver so yes i want big power. Im just TRYING not to spend a fortune getting it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MKcrxB16 »</TD></TR><TR><TD CLASS="quote">so what do you guys recommend? i got the b16 block for free, my cusin went ls/vtec and gave it me...i dont got much money as im a full time student with a shitty job n this is a project car, i have a daily driver so yes i want big power. Im just TRYING not to spend a fortune getting it. </TD></TR></TABLE>
Since your funds are low you only have 1 choice....Get b17a1 crankshaft and B17a1 rods and you'll have a 1.7Litre stroked b16a engine....Cause all the aftermarket stroker kits are expensive
Wow, you only have the bottom end? Why even bother, work on getting the top end of a B16, then get rid of the bottom end and spend the 300-400$ and getting a decent bottom end from an LS and make an LS VTEC. Might not have the best CR but it's a start.
If you spend $800 on a B18C bottom end that is goning to be much cheaper than trying to stroke a b16a. B17A1 part are difficult and expensive to come by. As Mr Speaker said, a GSR crank is going to require custom rods, etc. to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SomeDude56 »</TD></TR><TR><TD CLASS="quote">stock b20 bottom ends are **** if your going crvtec but the sleeves from what ive gathered are alright AS LONG AS YOUR NOT BOOSTING, If your goin crvtec A vtec oil pump, water pump, arp rod bolts, head studs, and shot peened rods In my opinion is a must for reliability.</TD></TR></TABLE>
duh?
duh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">Wow, you only have the bottom end? Why even bother, work on getting the top end of a B16, then get rid of the bottom end and spend the 300-400$ and getting a decent bottom end from an LS and make an LS VTEC. Might not have the best CR but it's a start.</TD></TR></TABLE>
i have a b16 head, springs retainers valves and a 5 angle valve job, so the tops ready to go...except for cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">If you spend $800 on a B18C bottom end that is goning to be much cheaper than trying to stroke a b16a. B17A1 part are difficult and expensive to come by. As Mr Speaker said, a GSR crank is going to require custom rods, etc. to work. </TD></TR></TABLE>
i thought about this too isnt this similar to a type r? gsr bottom end and b16 head?
this does sound pretty good thx mar...and yes i know i can go ls/vtec or crvtec but to be honest with you im not a big fan of the return oil line thing. and for now i want all motor but half way thru my project i decide to go on boost i dont like the idea of having 2 return oil lines know what i mean. but thx everyone the inputs great keep it comin!
duh?
Its a thread about making a b16 a 2.0 liter, figureded I should start with the basic info................dumbass
duh?
</TD></TR></TABLE>Its a thread about making a b16 a 2.0 liter, figureded I should start with the basic info................dumbass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 »</TD></TR><TR><TD CLASS="quote">Dude, just buy a 2l block if you want a 2l motor. Don't worry about trying to reinvent the wheel.</TD></TR></TABLE>
i know what you mean man but i dont want do some half *** **** know what i mean? yea im on a budget, but i would like a decent build. my bad if i seem indecisive but im trying to get as much info from ppl who know. as u can tell i dont know much.
Hmmm.....see sig.
Ive had no problems after a good tune. And its a ******* beast with 28psi.
Hmmm.....see sig.
