Will clutch for DOHC ZC also work on d15b2 SOHC?
Old Jul 18, 2006 | 08:28 AM
TAG's Avatar
TAG
Default Will clutch for DOHC ZC also work on d15b2 SOHC?
Hey,
I bought a Clutchmasters clutch for my DOHC ZC (no-vtec) 1.6 engine last year.
Does anyone know if this clutch will work on a SOHC d15b2 engine?
The description on my packaging says:
Spec: For "Honda Civic 1990 1991 1.5L / 1.6L FX300" Stage 3
Thanks
Old Jul 18, 2006 | 08:38 AM
4thgenhtch's Avatar
Default Re: Will clutch for DOHC ZC also work on d15b2 SOHC? (TAG)
As long as its for a cable tranny
Old Jul 18, 2006 | 08:59 AM
TAG's Avatar
TAG
Default Re: Will clutch for DOHC ZC also work on d15b2 SOHC? (4thgenhtch)
Weird - I just spoke with the place I bought it from (importparts.com) and the guy said it won't work because it's a SOHC motor ..?
I asked if there was someone there who was their "clutch spec GURU" just to make sure this info was accurate, and he said to call back in 1 hr so I will
My gut feeling says this clutch WILL work with the DOHC D-series motor/trannies...
Old Jul 18, 2006 | 09:09 AM
jlicrx's Avatar
it will work if you have a 90-91 flywheel and 89-91 (not 88) transmission
Old Jul 18, 2006 | 09:51 AM
TAG's Avatar
TAG
Default Re: Will clutch for DOHC ZC also work on d15b2 SOHC? (jlicrx)
Jlicrx, I remember you from thezcr.com
Thanks
I just got off the phone w/ the clutch guru at Clutchmasters
He said it will work pretty much with all D-series motors, trannies. woohoo
But I will take into consideration the flywheel and tranny info you posted Jli, thanks!
acmoc
12
Mar 10, 2010 07:56 AM
sawedoffcoupe
Aug 14, 2008 06:29 AM
pxsx
13
Jul 18, 2008 11:13 AM
Ignitecivic
May 11, 2002 05:13 AM
