EBAY CATALYTIC CONVERTER
Check engine light just came on and the reader said that I'm in need of a new cat. The ebay ones come with a bung for the o2 sensor and I really just need something that works and I don't give a **** that it "hi-flow". Has anyone ever tried it and if not, yay or nay?
watch out a lot of the hi-flow "cats" are not cats at all, they are just test pipes.
A real cat should cost you $100++, most of those test pipes are about $20 on ebay.
This is jsut a test pipe. http://cgi.ebay.com/ebaymotors...wItem
These are actually cats: http://www.modacar.com/product...DAHFC/
now will this test pipe fit will as a replacement for the cat? and once i replace that with a new o2 sensor, will it usually turn the check engine light off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bloodydc2 »</TD></TR><TR><TD CLASS="quote">now will this test pipe fit will as a replacement for the cat? and once i replace that with a new o2 sensor, will it usually turn the check engine light off?
they fit like **** and you will still have the check engine light.
look on summitracing. I think there's a cat for like $150-$200. bout as cheap as you'll get.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bloodydc2 »</TD></TR><TR><TD CLASS="quote">now will this test pipe fit will as a replacement for the cat? and once i replace that with a new o2 sensor, will it usually turn the check engine light off?</TD></TR></TABLE>
SMSP offers cats that will bolt right up in place of your exisiting unit, and funtion as a true catalytic converter, not just a test pipe.
antonio, bay, cat, catalyctic, catalytic, cheapest, check, converter, converters, ebay, ebaycatalitic, engine, honda, review, san
