swapping b18a into crx. HELP!!!!
Old Jul 17, 2006 | 07:10 PM
racingcrx's Avatar
Default swapping b18a into crx. HELP!!!!
yea my clutch went out today and i have the b18 sitting there and i need links for wiring what axles to use and stuff i need to do the swap with. i have motor mounts for it stage 3 clutch and headers. I NEED HELP BADLY TRYING TO FINISH BY TUESDAY AFTERNOON.
Old Jul 17, 2006 | 07:22 PM
racingcrx's Avatar
Default Re: swapping b18a into crx. HELP!!!! (racingcrx)
do i need a resistor box for the b18a? can i still use my stock radiator. and i am searching but finding nothing.
crxnj's Avatar
You use the 90-93 integra axles/halfshaft and remove the dust rings from inside the hub...Also if you have a dx you'll have to convert to multi point fuel injection,,,,if you have a hf you'll need different hubs si,dx,lx,ex, (anything besides hf/std)....You'll need a modified integra shift linkage or a custom built piece...
Also have to find out if the engine swap is 90-91 (obd0) or 92-93 (obd1)
Old Jul 17, 2006 | 07:28 PM
racingcrx's Avatar
Default Re: swapping b18a into crx. HELP!!!! (Mr.speaker)
its a OBD-0 motor i have a OBD-1 harness. but i am going to the junk yard in the morning. how much modifying do you need to do to the shift linkage?
Old Jul 17, 2006 | 07:37 PM
bag's Avatar
bag
http://www.performanceforum.co....html
Old Jul 17, 2006 | 07:44 PM
racingcrx's Avatar
thanks for the link. is all the dpfi to mpfi conversions that same for the b18a. like say you do the same way as the zc swap the dpfi to mpfi conversion. if you follow those instruction would it be the same for the b18a? thanks again for youe help
Old Jul 17, 2006 | 07:49 PM
bag's Avatar
bag
Default Re: (racingcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingcrx &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the link. is all the dpfi to mpfi conversions that same for the b18a. like say you do the same way as the zc swap the dpfi to mpfi conversion. if you follow those instruction would it be the same for the b18a? thanks again for youe help</TD></TR></TABLE>
Yes same thing..You may have to extend a wire or two but besides that its the same ..
Old Jul 17, 2006 | 07:52 PM
racingcrx's Avatar
THANK YOU VERY MUCH FOR THE INFO. I'LL GET PICS. I CAN'T BELIEVE I FRIED MY CLUTCH
my car is so slow. time for a upgrade
Old Jul 17, 2006 | 08:13 PM
gamble9465's Avatar
i got the b swap shiftlinkage for that swap and the axels for axels u want to use a 90 passgner and a driver 93 driver side axel thats wat i did i had a 90 on both sides and the driveer kept breakin so i did a 93 and it work great but if u need that shift linkage for that swap let me know.
Old Jul 17, 2006 | 08:14 PM
gamble9465's Avatar
u cna use the stock rad just take off the ac fan
Old Jul 17, 2006 | 08:21 PM
bag's Avatar
bag
Default Re: (gamble9465)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gamble9465 &raquo;</TD></TR><TR><TD CLASS="quote">i got the b swap shiftlinkage for that swap and the axels for axels u want to use a 90 passgner and a driver 93 driver side axel thats wat i did i had a 90 on both sides and the driveer kept breakin so i did a 93 and it work great but if u need that shift linkage for that swap let me know. </TD></TR></TABLE>
90-93 integra axles are all the same ****....Only difference is wether its abs or not and still they will work you should not be breaking axles...You did something wrong
Old Jul 17, 2006 | 09:11 PM
Loserkidwac's Avatar
Default Re: (bag)
Oem 90-91 were shorter than 92-93 but all aftermarket replacements are the same size...also there is no difference between abs and non abs, atleast every 90-93 axle I have seen all have the ring on for the ABS sensor
Old Jul 18, 2006 | 06:02 AM
racingcrx's Avatar
THANK YOU ALL VERY MUCH.
Old Jul 18, 2006 | 06:06 AM
haggar's Avatar
Just go to the FAQ in the stickied posts at the top of the fourm. All the links you need are there.
Old Jul 19, 2006 | 12:51 PM
racingcrx's Avatar
just a thing since i have another crx for parts. should i remove my body kit?
http://www.cardomain.com/ride/2097973
Old Jul 19, 2006 | 01:05 PM
psycho.chicken's Avatar
i like the body kit.. but the gay rear lights need to go...
Old Jul 19, 2006 | 01:06 PM
Default Re: (psycho.chicken)
Oh and yes, ABS are the same as non-abs...
I am running one of each...
guy on ebay sent me one passenger abs and one passenger non-abs... we tried both just for ***** and giggles.. both went right in... used non-abs on drivers side...
Old Jul 19, 2006 | 07:35 PM
racingcrx's Avatar
thanks. i do have a set of oem tail lights so i'll put them on...
Old Jul 20, 2006 | 09:37 AM
y-49's Avatar
i dont like the body kit, i would put it back to stock. but it is ur car ride how u wanna ride
xXhellxraiserXx
Jan 15, 2012 10:23 AM
2codys89CRX95GT
16
Jun 9, 2011 12:11 PM
kyle1jzsupra
Aug 29, 2008 02:57 PM
nicklk
Feb 26, 2005 10:34 PM
Ding
Oct 25, 2004 04:15 PM
