Integra not starting
I have a 92 integra LS and sometimes when i start the car it dies on me, i pump on the gas pedal to try and keep it running but it does no good it just shuts off on me its been doing this for the past month or two. It was doing the same **** last year so i asked around and they told me to check if it was getting any spark and if it was'nt that it was the dizzy so i went ahead and did that and got no spark so i went ahead and replaced the dizzy, it worked fine after that untill now. I know its getting fuel cuz i could smell it, so what could it be? Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calsonic »</TD></TR><TR><TD CLASS="quote">First check for spark. Then check if you can hear the main relay click on when you turn the key to the ON position.</TD></TR></TABLE>
Ok cool. so what do i do if i cant hear the main relay click, well they also told me i could be that when it was happening last year. If it is the main relay where is it located at? Thanks guys for your help!
