89 Civic throwing code 8 and 16, will start but won't run
Old Apr 21, 2002 | 02:47 PM
legendboy's Avatar
Default 89 Civic throwing code 8 and 16, will start but won't run
Car Will start but will not stay running. Throwing codes 8 and 16. Replaced the fuel filter,........there is fuel pressure at the filter too.
My dinky manual calls code 8 TDC position and 16 Fuel Injectors. I adjusted the valves the other day and it has been running fine untill last night. Car would not start after a whole day of driving, it sat waiting for a tow truck and about 1.5hrs later it started up and I barley made it home. (had to keep the gas on while at idle or it would have stalled) now its in garage and it wont start again.
Help Please! what are the proper engine codes ???
Old Apr 21, 2002 | 03:18 PM
Perfectionist's Avatar
Default Re: 89 Civic throwing code 8 and 16, will start but won't run (legendboy)
The TDC sensor is in the distributor. Make sure you didn't pinch or break a wire when you replaced the valve cover. The injector code 16 will set if there is a break in the electrical path for the injectors. That path basically is ignition switch---main relay---injector resistors (if applicable)---injector coils---and then the ECU grounds the circuit---plus all the wiring in between. BTW, the main relay has two functions. It energizes the fuel pump, and the other half powers the injectors. I'd start with the relay after a visual check confirms everything else is OK.
Old Apr 21, 2002 | 04:12 PM
89 CRX SI's Avatar
Default Re: 89 Civic throwing code 8 and 16, will start but won't run (Perfectionist)
Check your grounds
Old Apr 21, 2002 | 07:49 PM
legendboy's Avatar
Default Re: 89 Civic throwing code 8 and 16, will start but won't run (89 CRX SI)
thanks guys
Old Apr 22, 2002 | 01:35 PM
legendboy's Avatar
It was the ignition switch.............go figure!!!
ED3Sleeper
Oct 27, 2011 06:03 PM
{EF9} GrEaZe m0nKeY
Aug 12, 2009 09:26 PM
SupraRXZ
Apr 6, 2006 09:48 AM
