What parts should I get for Timing Belt change?
Old Jul 17, 2006 | 04:01 PM
fadedline's Avatar
Default What parts should I get for Timing Belt change?
Well I finally hear the dreaded timing belt rattle at low rpm's and its time to get the belt changed. Does anyone have a parts list or know off the top of their head what I should change while it’s all apart?
I know Im getting the belt, new auto tensioner, and water pump....and I figure ill get a valve adjustment and fresh fluids in everything.
Old Jul 17, 2006 | 05:20 PM
petern101's Avatar
Default Re: What parts should I get for Timing Belt change? (fadedline)
why dont' you just get a manual tensioner ??? anyways
if you do a valve adjustment, might as well get a new gasket set (honda sells it as a package)
some crush washers (since you prolly never changed them anyways and they are cheap)
maybe even some cam seals. other than that, you don't need much. if you are doing it yourself, i would def. recommend you to buy a helms manual. that manual will also tell you which parts to replace / torque specs / detailed writeups on how to do a timing belt job.
Old Jul 17, 2006 | 05:41 PM
EliTe 93Lude's Avatar
Default Re: What parts should I get for Timing Belt change? (petern101)
Where can I find a Helm manual?
Old Jul 17, 2006 | 05:42 PM
fadedline's Avatar
Cool thanx.....Ill get a Helms for sure. Should i get the manual tensioner...I heard that honda fixed the problem with the auto tensioners. Where can i buy them anyway?
Old Jul 17, 2006 | 05:44 PM
petern101's Avatar
Default Re: What parts should I get for Timing Belt change? (EliTe 93Lude)
you can order directly from honda, or go to helminc.com ??? or google helms manual
there are other ways (i.e pdf files) but honestly, having the manual right there is much better than having it on my laptop or printing out sheets.
there comes a time when you can be cheap and can't. with my information / tools / important car stuff (like a timing belt job) i don't skimp
Old Jul 17, 2006 | 05:45 PM
petern101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fadedline &raquo;</TD></TR><TR><TD CLASS="quote">Cool thanx.....Ill get a Helms for sure. Should i get the manual tensioner...I heard that honda fixed the problem with the auto tensioners. Where can i buy them anyway? </TD></TR></TABLE>
if you need a complete manual tensioner swap, i know a place that sells the whole kit (there are probably others too)
i just know of this place ( i buy alot of stuff from there). import replacement parts. they have the whole swap kit as well as honda timing belts / water pumps / other stuff
you might wanna try them
Old Jul 19, 2006 | 02:19 PM
fadedline's Avatar
Ok cool Im going to get the manual tensioner kit...where can I find the install instructions??
Today I was listening really close to my belt and now im not sure if the rattling i hear is the belt or something else!?! It almost sound like my damn valves are tapping or something...is that what the belt sounds like? It even does it when at idle...kinda like marbles in a can or when u shake up a spray paint can! Is that the normal rattling noise? Im kinda scared now...but if it were bent valves wouldnt it run like crap and loose power??
Old Jul 20, 2006 | 04:03 PM
fadedline's Avatar
Do i need a balancer belt too??
Old Jul 20, 2006 | 07:25 PM
Lude Acts's Avatar
Timing Belt, drive belts, crank seal, water pump, cam seal, and timing belt tensioner. This was all done on my 5G at 88k.
Old Jul 23, 2006 | 11:39 AM
fadedline's Avatar
Default Re: (Lude Acts)
Ok i was looking a the manual and they used a Timing Belt Slider...do you need this to change the timing belt? If so where can i buy one?
Old Jul 23, 2006 | 11:50 AM
pinecone's Avatar
Default Re: (fadedline)
I probably need to do this soon, while the engine is out.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 &raquo;</TD></TR><TR><TD CLASS="quote">if you need a complete manual tensioner swap, i know a place that sells the whole kit (there are probably others too)
you might wanna try them</TD></TR></TABLE>
What is the name of this place? What is their website.
Old Jul 26, 2006 | 06:50 PM
fadedline's Avatar
Default Re: (pinecone)
anyone know if i need the Timing belt slider thing??
smillion
Honda Civic (2001 - 2005)
Feb 14, 2014 12:25 PM
utn
May 14, 2008 08:35 PM
mixmastermatt
Feb 25, 2007 06:37 PM
ZXRider
Dec 31, 2006 04:07 PM
dragontegz
May 8, 2003 07:56 AM
