RSX Steering Wheel Fit DC2?
Seeking out options for a smaller SRS cruise control steering wheel to put on my Integra. Any ideas on whether the RSX steering wheel will: 1) fit ) work with SRS and cruise functions?
Thank you in advance!
it wont fit on the integra steering column... but it fits on civic si steering column.... since the integra and civic were built off the same chassis... it could be very possible that you could bolt on the civic si steering column onto a dc chassis and then put the rsx steering wheel on that... i am currently looking for this answer too.....
rsx steeringwheel in a civic si.... it is a wonderful steeringwheel... the first time i held one it was in a wrecked rsx in the junkyard... i didnt know it was an rsx at first but i was very impressed with the feel of the steeringwheel and shocked when i discovered it was infact an rsx.....
the steeringwheel looks stunning.... would look totally awesome in a dc... i am currently am doing the tan to black interior conversion... and all i am missing is a black steeringwheel... and i want the rsx wheel.
As is it will not fit. But you can cut the splined part of the off the RSX wheel and weld one from a DC onto it and then it would. Here is a CTR wheel moded to fit an Integra.
As far as the wiring... I am sure you can re-pin some things and it will come together.
Modified by Comp97GSR at 9:52 PM 7/17/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LordAphotic »</TD></TR><TR><TD CLASS="quote">it wont fit on the integra steering column... but it fits on civic si steering column.... since the integra and civic were built off the same chassis... it could be very possible that you could bolt on the civic si steering column onto a dc chassis and then put the rsx steering wheel on that... i am currently looking for this answer too..... </TD></TR></TABLE>
bump for two minds that think alike.
no is not going to work, you have to use ek steering column inorder to use rsx/s2000 wheels, if you want to get something for your dc, try to get jdm srs itr steering wheel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db »</TD></TR><TR><TD CLASS="quote">no is not going to work, you have to use ek steering column inorder to use rsx/s2000 wheels, if you want to get something for your dc, try to get jdm srs itr steering wheel </TD></TR></TABLE>
how many times does this guy have to say this? LOL
you can make an EK steering column fit in an integra.
but cruise control and stuff may need to be rewired to work. plugs might be different.
