91 dx fuse layout
Old Jul 17, 2006 | 01:54 PM
projsectEF's Avatar
Default 91 dx fuse layout
does anyone have a copy of a 91 civic hatch dx fuse layout under the dash.
mine didn't come with one and some things aren't working in my car.
Old Jul 17, 2006 | 02:27 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: 91 dx fuse layout (projsectEF)
this is a '90 crx Si.. Might help:
Old Jul 17, 2006 | 09:23 PM
Dave_Darling's Avatar
From the Helm's manual (just a text list, sorry!!) --
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">This is the layout for the 1990 CRX, from the factory (or Helm's) manual. The fuses are numbered; you should be able to see the numbers on the fuse box. Or boxes, rather, there are two. One is in the engine bay, the other is under the dash.
Main fuse box:
#34 - 10A - hazard lights; PGM-FI ECU; integrated control unit; automatic seat belt control unit
#31 - 60A - battery to alternator circuit
#35 - 15A - horns; brake lights; key interlock solenoid (A/T only)
#37 - 15A - PGM-FI main relay
#38 - 15A - condensor fan motor; A/C compressor clutch
#32 - 60A - ignition switch
#33 - 50A - lighting circuit
Dash fuse box:
# 6 - 30A - sunroof motor
#19 - 30A - blower motor (note: Auxiliary fuse holder)
#17 - 10A - stereo
#18 - 10A - heater mode/recirculation motor; condenser fan motor relay; A/C compressor clutch relay; rear window defogger relay
#15 - 15A - radiator fan motor; radiator fan motor relay
#16 - 10A - daytime running light (Canada only)
#13 - 15A - wiper and washer motors; sunroof relay
#14 - 10A - voltage regulator; Emission control solenoid valves; PGM-FI main relay; ELD unit (USA only); EACV
# 1 - 10A - integrated control unit; autmatic seat belt control unit
# 2 - 10A - starter signal; integrated control unit
- - - - 8-12 below are USA only - - - -
# 8 - 10A - dashlight brightness controller; dashlights; side marker lights; taillights and license plate lights; integrated control unit
#10 - 10A - left headlight (low)
#11 - 10A - right headlight (low)
# 4 - 10A - right headlight (high); high beam indicator light
# 5 - 10A - left headlight (high)
#12 - 15A - stereo; clock; interior lights; cigarette lighter; integrated control unit
- - - - 8-7 below are Canada only - - - -
# 8 - 10A - dashlight brightness controller; dashlights; integrated control unit
# 4 - 10A - right headlight (high); high beam indicator light; daytime running light relay
#12 - 15A - stereo; clock; interior light; cigarette lighter; integrated control unit
# 7 - 10A - daytime running light relay to side marker lights; taillights and license plate lights</TD></TR></TABLE>
--DD
Crocky
Apr 19, 2017 11:03 AM
switters959
Nov 27, 2011 12:17 PM
96WhiteOnBlack
Dec 19, 2007 07:25 PM
Firedrake1
Jul 27, 2004 08:09 PM
