Valve Cover HELP.......... :)
Old Apr 21, 2002 | 01:17 PM
intekragsr's Avatar
Default Valve Cover HELP.......... :)
Today I want to paint my valve cover red. This is what I need help on.
When I take it off, what are the torque specs on the bolts when I put it back on and whats the order I put the bolts/nuts back in? Is there anything I need to remember when taking it off and putting it back on? I dont want to mess anything up.
Thanks for the help and your time in advance
Old Apr 21, 2002 | 01:47 PM
smkngsr's Avatar
Default Re: Valve Cover HELP.......... :) (intekragsr)
theres nothing u need to remember except for the firing order for the wires that u have and when u put them back together make sure that u only hand tight those nuts...if u do it too tight u will break them...hope this helps...
Old Apr 21, 2002 | 02:46 PM
intekragsr's Avatar
Default Re: Valve Cover HELP.......... :) (smkngsr)
thanks
Old Apr 21, 2002 | 02:56 PM
smkngsr's Avatar
if ever u get lost just e mail me and i will walk u through...but i dont think u will get lost...im talking bout the firing order...thanks
Old Apr 21, 2002 | 03:15 PM
91DA9's Avatar
be careful with the studs that hold the valve cover on they break EASILY!!!!
Old Apr 21, 2002 | 03:27 PM
intekragsr's Avatar
Default Re: Valve Cover HELP.......... :) (94IntegraGSR-OVR)
so hand tighten all the studs? There are no torque specs? Thanks for the help guys
Old Apr 21, 2002 | 04:43 PM
boosted1993fd's Avatar
yeah…don't use a torque wrench. It is pretty inaccurate for the small amount you'll be torquing them down.....I used a torque wrench a long time ago and broke off a stud...which is easy to replace...but still a pita. Just tighten them down using a criss cross pattern….and do it till they feel snug….oh yea…don’t forget to use Honda-Bond on the valve cover gasket on the 8 or so spots.
Old Apr 21, 2002 | 04:48 PM
fiebru1119's Avatar
Default Re: Valve Cover HELP.......... :) (Interlude)
if you are going to reuse the original gasket then lighten it like 5ft/lbs less than what factory specs say. if you are get a new seal, then just torque it down to factory specs... if youre gonna guesstimate it, then only do it hand tight
Old Apr 22, 2002 | 12:08 AM
SIK IN DA HED's Avatar
New User
Default Re: Valve Cover HELP.......... :) (fiebru1119)
yeah dont do it too tight. those nuts break the studs off easily. hand tight. one hand... not two.
Old Apr 22, 2002 | 01:16 AM
intekragsr's Avatar
Default Re: Valve Cover HELP.......... :) (dlplayboy)
ok just finished, and omg it looks soo nice pix 2m
oneEg1Tc
12
Nov 21, 2009 07:57 PM
chuniepatuni
Nov 29, 2006 01:29 PM
TeamTooQuick
May 18, 2002 08:18 AM
CrOmEdOmEcHaMbEr
Mar 18, 2002 02:23 PM
vtec-outlaw
Feb 12, 2002 05:16 PM
