My 98 integ can't hold a charge
Old Jul 17, 2006 | 08:41 AM
crxma22's Avatar
Default My 98 integ can't hold a charge
i need some help or info on my car, it's a stock 98Ls the car drives for a day or as long as the charge in the battery will hold up, and then the radio shuts off, the tach & mph will drop to zero then my car will just die... i replaced the alternator and bought a new battery.. same problem.. any ideas on how to correct it?
Old Jul 17, 2006 | 10:40 AM
mattcivic's Avatar
Default Re: My 98 integ can't hold a charge (IGGYINTEG)
have u checked all your fuses? was the alternator new or did u get a used one if so did u test it?
Old Jul 17, 2006 | 11:06 AM
crxma22's Avatar
Default Re: My 98 integ can't hold a charge (mattcivic)
under the hood or under the steering wheel? i bought a new alternator from kragen a basic one not any of that led fancy stuff.. how would you test it before putting it in?
Old Jul 17, 2006 | 12:08 PM
lsvtek's Avatar
Default Re: My 98 integ can't hold a charge (IGGYNTEG)
If you mean how to test a alternator? all you do is go to kragen and autozone, i think they have a alternator tester or something
aziaticvang
Jan 7, 2008 03:59 PM
SupremexGSRx
Sep 25, 2007 01:00 PM
MidShipCivic
Acura TL, RL & ZDX
Nov 5, 2006 03:12 AM
85mm LS VTEC
12
Jul 26, 2005 04:13 PM
ck279
Oct 12, 2001 05:27 PM
