Got my JDM front end now need some help with the install
Got my jdm front end for my 90 si hb. If anyone has a quick tutorial on how to take the fenders off i would appreciate it. I think i can figure the rest of the body parts, as for the fenders i see where they are connected (in between the door) and I was wondering if I had to take the doors off in order for me to reach the bolt that holds the fender to the frame.
Thanks.
Thanks.
1. 3x10mm bolts inside the hood.
2. 1x10mm bolt at the underside of the fender by the door, bolted to rocker panel.
3. 2x10mm bolts under the bumper, hidden from view.
4. 2x10mm bolts inside the door jam, use a 1/4 ratchet with a 6" extension, works great, open the door all the way and you should see them.
Good luck.
Good luck.
Fog Lights
https://honda-tech.com/zerothread?id=1060330
You want need to cut your bumper, but it gives you and idea on how to mount it and the wiring I beleive is in there, only thing I could find.
Side Markers
http://tuner-junction.com/TJFo...=2307
FAQ is the ****.
Side Markers
FAQ is the ****.
where did you get the front end conversion? how much did it cost, and also with shipping? how long did it take to reach? thanks
ef9robert
24
Aug 7, 2007 05:43 PM
