***A/C Help Needed... searched already****
Ok the a/c clutch stopped engaging a few days ago out of the blue.
- I checked both relays and they are good (the ones on the front of the car by the condensor).
-Pulled the plug for the pressure sensor and jumped the harness(this caused the fans to turn on and the idle to raise)
-Checked fuses but can't seem to find one for the AC system
-Lastly I ran a wire to the compressor while the A/C switch was on ect... and the cluch engaged and I had AC for the quick second.
- System has pressure on both high and low sides.
Any ideas? I dont really want to hack the car ( cause I could just run a simple relay to engage the clutch ) Id rather fix it correct. Any help?
g2turbo
Jul 18, 2006 05:36 AM
Magick211
Feb 23, 2003 07:00 PM
