rear brakes
upgrade the brake pad material and the other commone parts, larger master cylinder and rear disk proportioning valve, 90-91 CRX Si is 2040
if you wanted to do anything elase i would maybe look at rebuilding the rear calipers if they are older. The larger brakes wont make you stop any faster, it just keeps the pads from overheating.
spend the money on good tires, which is going to make a bigger difference in stopping then replacing your rear brakes.
rajan
Nov 2, 2016 06:01 AM
bseriesboosted
Sep 22, 2003 08:30 PM
