Replacing coolant hose from TB to upper rad. hose?
Old Jul 16, 2006 | 03:47 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Replacing coolant hose from TB to upper rad. hose?
A coolant line running from the TB to upper radiator hose has sprung a small leak, and I need to replace it. It looks to be about a 3/8" hose, possibly smaller. This is on a 96 GSR motor.
Should I get a replacement hose from Acura, or what type of hose should I use from a parts or hardware store? Would I need fuel hose, or heater hose, etc?
Old Jul 16, 2006 | 04:41 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Replacing coolant hose from TB to upper rad. hose? (boostincoupe)
Here is a link to various water hoses on the 96 GSR:
http://www.acuraparts247.com/s...ch=no
It's up to you where you want to pick up the hose. I usually prefer to go to Honda/Acura for the hoses, as they are exact fit (with the right bends) and usually are not very expensive.
Old Jul 16, 2006 | 05:56 PM
Default Re: Replacing coolant hose from TB to upper rad. hose? (tech8)
That is so damn confusing to look at
For under $10, I'll just swing by the dealer
Old Jul 21, 2006 | 12:21 PM
Is it true that I can just use 3/8" fuel hose to replace the ripped coolant hose?
At least, as a temporary fix?
Old Jul 23, 2006 | 11:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">Is it true that I can just use 3/8" fuel hose to replace the ripped coolant hose?
At least, as a temporary fix? </TD></TR></TABLE>
liquidx
Aug 21, 2010 10:02 AM
nihkon
11
Sep 13, 2009 05:54 PM
PatrickGSR94
Aug 12, 2008 09:52 AM
crxpwr1
28
Jan 24, 2007 06:47 PM
hose
Honda Motorcycles
Jun 19, 2006 08:28 AM
