Turn Signal Issue (Question Inside)
Ok well today I found out my pax side corner turn signal isnt working for turn signal or hazard - all the rest all the way around still work just fine I chk'd the socket and no voltage us geting to it fuses are all good ay idea where to go from there I pulled the hazard relay and tried a jumper to see if it would work that way and no go so Im kinda lost could the signal switch be bad but still work for pax side bumper turn signal and hazard but be bad as in regards to the corner turn signal ?
Im lost any ideas would be great
if the signal switch was bad, none of them would work. if a relay was bad i doubt that one would work with out the other. i would have to say to start tracing the wire and there will probably have an open in it somewhere
slammed4dreg
26
Nov 16, 2014 04:24 PM
