piston/rod quest
Old Jul 16, 2006 | 09:07 AM
GarageAlchemist
Guest
Posts: n/a
Default piston/rod quest
the rod that goes threw the top of the connecting rod and in the piston is VERY VERY snug going threw the rod, but not the piston, not i doubt it will move around on the rod, but of course it will on the piston.
So.. is this right.. or should bolth the rod side move, and the piston side as well..
Old Jul 16, 2006 | 10:54 AM
silentvoice19's Avatar
Default Re: piston/rod quest (GarageAlchemist)
man you gotta remember tight tolerences are good here but not to tight if its too loose it will bang that wrist pin clean outa the piston if its way to tight which is problly isnt it'll seize. In all its fine i think wrist pin sizes and rod sizes if ordered for the same motor are machined to spec use some lube to put it in.
turboef90
Oct 11, 2013 04:38 AM
b18c5_ej8
Nov 26, 2011 05:07 PM
lsvtecek18
Oct 19, 2006 05:47 PM
bretx0r
Apr 7, 2003 08:22 PM
batman_22
Oct 23, 2002 08:28 PM
