Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
How To remove FACTORY OIL FILTER?!?!
Old Jul 16, 2006 | 08:24 AM
kevinm30's Avatar
Default How To remove FACTORY OIL FILTER?!?!
I been tryin for 2 hours now and cant seem to get it off. I been to the auto store 3 times buyin filter wrenches and still i cant get it off. I bought the strap type,and the one that fits over the filter like a giant wrench still i cant get it off.The car is sittin In my driveway with a hole in the filter because i tried the puttin a screwdriver method through it. The stupid factory always puts these filters on extreamly tight. Anyboy have any suggestion that will help me get it off?
Old Jul 16, 2006 | 09:31 AM
SpoolnG2's Avatar
Default Re: How To remove FACTORY OIL FILTER?!?! (kevinm30)
Yeah, while the car is jacked up take off the passenger side wheel. Its much more accessible from there. Then slide a filter wrench in there and your set. Thats what i did and it was cake, no problems at all.
Old Jul 16, 2006 | 09:53 AM
kevinm30's Avatar
Default Re: How To remove FACTORY OIL FILTER?!?! (SpoolnG2)
Dude they musta put my **** on with locktite because it isnt budging
Old Jul 16, 2006 | 11:27 AM
eL's Avatar
eL
edit:
You have an EX and you cant get the filter off? That's hard to believe. If you have any sort of leverage it should come off very easy. I used one of those strap "wrenches".
Old Jul 16, 2006 | 06:23 PM
01usjdmr's Avatar
You need the factory tool or a set of oil filter pliers. The first oil change is always pretty tight.
Old Jul 16, 2006 | 06:53 PM
01-1293's Avatar
Default Re: (01usjdmr)
same thing happened to me......spent $25 on all these oil wrenches and **** and couldn't get it to go.....took it to a local shop and they even had trouble getting it off.....took them 20 mins
Old Jul 17, 2006 | 05:21 AM
FBPSidan's Avatar
I do civics everyday at work, the first oil change is always the hardest cuz everything is on so damn tight, do the wheel method (if you have an si) if you have a regular one i dunno what to tell you, the filter is right there. we use the honda oil filter wrench, works like a champ.
Old Jul 17, 2006 | 09:03 AM
SpoolnG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, while the car is jacked up take off the passenger side wheel. Its much more accessible from there. Then slide a filter wrench in there and your set. Thats what i did and it was cake, no problems at all.</TD></TR></TABLE>
Funny, thats what i said.
Old Jul 17, 2006 | 11:32 AM
doughhall's Avatar
Too bad you put a hole through it or you could let the car run a few minutes to get it warm. They always come off easier when the block is hot. I have a set of channel locks - not the standard kind, but made for pipe, that I use when things get out of hand. That usually does the job.
Old Jul 17, 2006 | 02:56 PM
kevinm30's Avatar
I finally got the **** off with a good steel strap wrench, just beware, if your doing it youself for the 1st time you will need the right tool. I was lucky because i can barely get the strap wrench on because the filter is kinda flush with the underbody.
Old Jul 17, 2006 | 04:19 PM
airportguy770's Avatar
yeah my first oil change was a pain. I think they have a giant gorilla put them on at the factory. I wrapped mine in a rubber pad thats used to open jars, and with a lot of grunting and swearing it came off.
Old Jul 17, 2006 | 05:42 PM
79 TRANS AM BITCH's Avatar
Default Re: (eL)
the poke a hole trick usually works on most cars, unless its cartridge, dont do that if its a cartridge filter.
Old Jul 17, 2006 | 05:51 PM
spoonlongblock's Avatar
for si this works great if you have a ratchet a long extension a swivel socket and a adjustable filter wrench you can go thru the hole just above the tie rod and it will come off easily
ninety-five_DB
Jul 8, 2006 05:03 PM
Understeer
Jun 7, 2003 10:58 AM
Halo
Sep 26, 2002 11:53 AM
EKB18BPR3
11
Aug 18, 2002 11:53 PM
Type Goch
Jul 1, 2001 10:11 AM
