Lift points
Thanks for double posting this here and GDD.
I found this by using the "search" tool. Not sure if it 100% what you need, but it should help.
Take engine hoist, mount chains to motor, on the right side (driver side) of the intake manifold there is spot, use a bolt and washer and mount chain to back of the block. On the driver passenger side, i removed 1 of the tranny bolts, and put my chain and washer there and put the bolt back into the tranny. jack up hoist to remove the slack.
- Remove remaining mount bolts, take mount bolts and keep them with there respective mount somewhere out of the way.
- Once you have removed all of the mounts and bolts the motor should be hanging there freely unless you have forgot something, give the car a once over and verify that nothing is preventing you from pulling the motor out of the car, If not then proceed to jack the engine hoise until the motor will clear the headlights and the upper radiator support.
- Slide hoist back and move it until the motor is out of the way and in a spot that you can work on it.
For detailed pictures and bolt sizes etc... (refer to Pages 95-107 in attached civic helms pdf manual)
johnzm
Jul 26, 2002 10:01 AM
