H22 Lag Through Low RPMS (0k - 4k!) Need Help!
Old Jul 15, 2006 | 09:29 PM
vtec420kingH22's Avatar
Default H22 Lag Through Low RPMS (0k - 4k!) Need Help!
Just finished my h22a swap in my ek civic! Second time this motor is dropped in this car but this time it is fully rebuilt. Not built, rebuilt. Motor has a clean idle after warming up, and the ecu is throwing no codes at all. I am running a chipped P28 ecu. But for some reason the car feels like it has no power at all. In the lower RPM range it seems to have some kind of lag on it. When you drive the car you can feel the motor trying to push but it just lags. Anybody have any familiar problems like this that can help me? Or have any ideas? Motor only has about 80 miles on it!
Please Help!!
Old Jul 15, 2006 | 10:19 PM
hu's Avatar
hu
Out of curiosity, did you get a chance to drive the H22a in a car before the swap? Probably not...
Can you be a little more specific with the problems?
Old Jul 15, 2006 | 11:05 PM
Default Re: (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">Out of curiosity, did you get a chance to drive the H22a in a car before the swap? Probably not...
Can you be a little more specific with the problems? </TD></TR></TABLE>
Yes I did, this motor has been mine for about 3years.. Did a complete rebuild after having problems with it for awhile. Motor should be pulling alot harder then it is doing now. Trying to figure out why it is laggin, car just seems to lag on take off and during second gear. Car sort of jumps in a sputter way, cant seem to explain it right
Old Jul 16, 2006 | 02:14 AM
iwubmybb4's Avatar
Default Re: (vtec420kingH22)
hmm.. mine did the same thing with my jdm p13.. i used a chipped p28 (crome) and now it doesn't lag any more... try using a different ecu... oh.. and is the car tuned?
Old Jul 16, 2006 | 04:44 AM
roller3804's Avatar
spark plugs, O2 sensor...ignition timing
Old Jul 16, 2006 | 06:45 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (roller3804)
mine does the same damn thing...
Old Jul 16, 2006 | 09:33 AM
pizzamanprelude's Avatar
Default Re: (AnthonyG2003)
mine does it, particularly when cold on part throttle, feels like the ignition is being pulled.
Old Jul 16, 2006 | 10:23 AM
oranginal's Avatar
Default Re: H22 Lag Through Low RPMS (0k - 4k!) Need Help! (vtec420kingH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec420kingH22 &raquo;</TD></TR><TR><TD CLASS="quote"> In the lower RPM range it seems to have some kind of lag on it. When you drive the car you can feel the motor trying to push but it just lags.
i just had my timing adjusted when i went to the dyno last week and i am having the same problem. i wasn't sure if it was just me but i am going to find out
Old Jul 16, 2006 | 01:49 PM
BlueJdm's Avatar
Mine does the same thing as well...its not that bad tho it feels like a slight power surger right before its hits 4000 rpms
Old Jul 16, 2006 | 02:53 PM
vinuneuro's Avatar
Default Re: (BlueJdm)
Same problem here, not too extreme but I notice it. I had a egr cel, cleaned the valve, feels slightly better. Am going to clean out the metering ports in the intake manifold next weekend, from what I've read, that should help a bit as well.
Old Jul 16, 2006 | 05:38 PM
Default Re: (vinuneuro)
still havent found any solution to this problem..car seems to be doing ok through first until it hits about 5k then it feels like it has no power! also in second gear seems to be a little jerky.. no other ideas
Old Jul 16, 2006 | 05:56 PM
T-King's Avatar
Im sure they did (not sure if have to do this for the p28) when they set your ignition timing on the dyno did they jump the plug to adjust the timing. Get a timing light and check your timing it should be at 15 at a base idel,if its lower like 14 thats your probelum.
Old Jul 16, 2006 | 08:58 PM
Default Re: (T-King)
ok, never thought of that..dont have a timing gun, around how much do they cost? and where can I get one from?
Old Jul 16, 2006 | 09:19 PM
hella_usdm's Avatar
I vote for replacing the cap, rotor, plugs and wires.
Old Jul 16, 2006 | 09:24 PM
Default Re: (hella_usdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hella_usdm &raquo;</TD></TR><TR><TD CLASS="quote">I vote for replacing the cap, rotor, plugs and wires.</TD></TR></TABLE>
Motor only has 100 miles on it now, never did change the wires I can try that. I have msd ignition think I should get msd wires? have brand new plugs!
Old Jul 17, 2006 | 10:28 AM
lunaticracer21's Avatar
bump!!
Old Jul 17, 2006 | 11:32 AM
zo4000's Avatar
my jdm f22 did the same damn thing..i had the timing adjusted and it feels alot better,now it just hesitates under 2k rpms.
Old Jul 17, 2006 | 06:27 PM
rich045's Avatar
* B A N N E D *
check your cat, it might be clogged, thats what happened to mine.
Old Jul 17, 2006 | 07:44 PM
Default Re: (rich045)
and how would i go about checking my cat? can I take this apart?
Old Jul 17, 2006 | 07:59 PM
rich045's Avatar
* B A N N E D *
well check it, drive the car, it'll feel very jerky, keep drivin, see if it overheats, if it does i am almost cetain it is the cat. since there is not enough flow out, all that hotness stays in and causes more stress on hte motor.
Well you can try that, it might be your ecu, swap ecus and see the problem still remains.
Old Jul 17, 2006 | 08:01 PM
car does feel jerky in second, does not overheat though, i am running a chipped p28 ecu for the h22, i could try my friends p72 see what that does..
Old Jul 17, 2006 | 08:14 PM
rich045's Avatar
* B A N N E D *
how about you try a stock or jdm p13 (they are the same ****) in good working conditions and see how it goes? cause if it turns sluggish with a p28 right before the vtec point, then theres something wrong. is this p28 chipped? if so what is it chipped with? crome? uberdata? neptune?(not sure if thats teh name)
Old Jul 17, 2006 | 08:18 PM
rich045's Avatar
* B A N N E D *
i have a bad p13, a p13 stock, a p13 jet chipped, p14, and a p28 chipped with crome. the bad p13 of course didnt start ****, the stock runs the car wack, the p13 jet chipped runs a bit better, when i had the p14 it ran good, the p28 burned my map sensor... so stick with a p13 for now, thats what i'm doing
Old Jul 17, 2006 | 08:20 PM
i had a p13 when i originally got the motor swap, the reason i went with a p28 was because the shop i went to said i couldnt chip the p13. I am not running a egr and I forget what else. They are both cancelled out on the p28
The p13 made the car run not to good when I had it!
Old Jul 17, 2006 | 08:25 PM
rich045's Avatar
* B A N N E D *
so thats a stock p28 with just the egr canceled? are you running the basemaps of the p13? if not then you gotta have them or else your car is gonna run like a civic... LOLLLLLLLL
Go back to your shop and ask them what kind of chipset did they use? i hope they use crome pro since you have datalog it and test run it outside the car without having to put your car at risk.
