how to degrease or clean up dirt around hub knuckle ring ****PIC***
Old Jul 15, 2006 | 08:06 PM
Turbo Dan's Avatar
Default how to degrease or clean up dirt around hub knuckle ring ****PIC***
see all that nastyness in there, all the dirt and grime and oil and wd40 and grease.
is there a way i can clean up that area safely so that i dont damage the seal or anything around it?
any tips would be much appriciated.
the last few posts you guys have dont a great job of answering my questions so keep her going
Old Jul 15, 2006 | 08:08 PM
y-49's Avatar
i would use carb cleaner, after u clean it spray a little wd40 in it so the carb cleaner dosent dry the bearing and seal out
Old Jul 15, 2006 | 08:12 PM
Crx Jimmy's Avatar
Default Re: how to degrease or clean up dirt around hub knuckle ring ****PIC*** (Turbo Dan)
pressure washer
Turbo Dan's Avatar
Default Re: (crxbeatinu)
should i add grease to the seal once its been cleaned?
i have a really strong engine cleaner (gunk), do you think it would harm the seal?
Old Jul 15, 2006 | 08:51 PM
Crx Jimmy's Avatar
Default Re: (Turbo Dan)
I wouldnt use any kind of solvent near the bearings, just use a pressure washer and some soap with a stiff brush
Old Jul 15, 2006 | 09:02 PM
Hamstr323's Avatar
Default Re: (Crx Jimmy)
brake cleaner
Old Jul 15, 2006 | 09:48 PM
Lamchop0000's Avatar
brake/carb cleaner, with a tooth brush
Old Nov 16, 2006 | 11:39 AM
repn a lude's Avatar
Default Re: how to degrease or clean up dirt around hub knuckle ring ****PIC*** (Lam.N)
just a toothbrush
EG-SIXV-TEC
Jan 19, 2010 01:10 PM
Hanmin
Transmission & Drivetrain
Dec 26, 2008 11:44 AM
Peter Brady onlyonweekndz
Nov 26, 2007 12:55 AM
johnzm
Mar 7, 2004 12:05 PM
intekragsr
May 8, 2003 05:04 PM
