spark plug, leaking is this a problem? - see pic
Old Jul 15, 2006 | 11:55 AM
fugaziman's Avatar
Default spark plug, leaking is this a problem? - see pic
Here's a picture of my spark plug that appears to be leaking. What could the problem be?
Best resolution?
Thanks for any help
Old Jul 15, 2006 | 11:56 AM
soon2bdropped's Avatar
Default Re: spark plug, leaking is this a problem? - see pic (fugaziman)
the seal underneath the VC thats for the sparkplug????
Old Jul 15, 2006 | 12:03 PM
lVlemphizStylez's Avatar
Default Re: spark plug, leaking is this a problem? - see pic (soon2bdropped)
oil shouldnt make it past the rings of the piston in that amount...i dont think you have a leak...you sure you didnt spill something??? because itd be real unsual to see that amount of oil make it up there
Old Jul 15, 2006 | 12:20 PM
jdm_bones's Avatar
If that is oil, you could have a blown headgasket...Remove that sparkplug wire and try to remove as much of that oil with some rags...Check the rest of your plugs, because it might not be the only one that is flooded...New headgasket and head resurfacing is needed GL!
Old Jul 15, 2006 | 12:23 PM
Default Re: spark plug, leaking is this a problem? - see pic (jdm_bones)
a blown headgasket wont cause the oil to pass through the seal on the sparkplug over the chamber..
Old Jul 15, 2006 | 12:32 PM
fugaziman's Avatar
Default Re: spark plug, leaking is this a problem? - see pic (lVlemphizStylez)
Thanks for the replies, I'm replacing the spark plugs and cleaning the area and will let you know what happens
Old Jul 15, 2006 | 12:36 PM
JThrasher79's Avatar
the valve cover gasket ring is bad oil is coming in from there. replace all your vc gaskets
Old Jul 15, 2006 | 12:38 PM
jdm_bones's Avatar
Remove the sparkplug wires and take picture and post it so that I can take a better look at the problem...
honda.girl.1991
Sep 5, 2013 06:56 PM
EG6_978
Sep 13, 2008 02:37 PM
sprco
Jul 2, 2008 09:54 AM
St3v3
Dec 27, 2004 04:01 PM
ZexyAccord
Jul 26, 2004 06:14 PM
