finishing up GSR into DA swap, 3 things i dont know where they go (pics)
as described theres a smaller tube u cant see im guess its something to do with coolant but i have no idea where that or the larger one closer to the drivers side goes
no idea where thins one goes either, thanx is advance guys.
i will investigate the larger tube for you when i get back to my car...as far as the little nipple...i had a tube from the TB (vacuum hose) that i stuck on that...
I just took a look at my DA, if its anything like the 1st gen B16 the big coolant hose coming from the black metal tube goes to the oil cooler and if i saw the same small hose as you it also come from th metal tube and goes to the back of the manifold to a round "thing" (not sure what its called) and plugs in to the drivers side nipple
9000rpms
Sep 27, 2006 08:19 AM
coot_er
May 14, 2004 01:52 PM
