Car bogging
Old Jul 15, 2006 | 09:41 AM
teler86's Avatar
Default Car bogging
I recently installed an obd-1 b16 into my crx, it runs great but has one issue, after long drives about 45min to an hour the car feels like it looses a significant amount of power at and past 3k rpm, in fact it is reluctant to even rev past 3k rpm you must floor the throttle and just wait. It only does this after it has been ran for a long time. The car will start to slightly smell of gas as well anybody have any idea of what this could be???
Old Jul 15, 2006 | 12:27 PM
saikouEF8's Avatar
Default Re: Car bogging (teler86)
what smells like gas? whats ur temp gauge doing? see any smoke? happen in all gears? idle ok? check ur oil? coolant? throwing any codes? where did u get the b16?
Old Jul 15, 2006 | 08:32 PM
teler86's Avatar
Default Re: Car bogging (saikouEF8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saikouEF8 &raquo;</TD></TR><TR><TD CLASS="quote">what smells like gas? whats ur temp gauge doing? see any smoke? happen in all gears? idle ok? check ur oil? coolant? throwing any codes? where did u get the b16?</TD></TR></TABLE>
The car starts to smell like gas
the temp gauge stays steady does not move
There is no smoke
The idle is a little high always about 1200rpm
oil and coolant are fine
I am not throwing any codes
and i got the motor from japandirect a reputable company
Old Jul 17, 2006 | 05:31 PM
teler86's Avatar
anybody?
Old Jul 17, 2006 | 05:38 PM
Contender25
Guest
Posts: n/a
Getting enough fuel?, maybe fuel pump going out possible?, what gas are you using in your b16a?. You know, mine kinda does that after a long hot day of driving and occasionally punching it, and pretty much my clutch is about fried.
Old Jul 17, 2006 | 05:43 PM
firme ef8's Avatar
Default Re: (Contender25)
mine does about the same thing(feels like it lags after a while of driving).
Old Jul 17, 2006 | 05:46 PM
Contender25
Guest
Posts: n/a
Well your clutch does heat up a bit after driving for a while or getting on it alot, thats what that lag might feel like.
Old Jul 17, 2006 | 05:58 PM
Cuda70's Avatar
Could be your cat. Do you also detect the faint odor of rotten eggs?
Old Jul 18, 2006 | 07:49 PM
teler86's Avatar
Well i see 2 problems with your suggestions guys, 1 i dont have a cat, i replaced it with a resonator from ebay, and 2 it is a stage 3 clutch master clutch which i installed with the motor swap also, if the clutch was slipping my motor would still rev, however it does not it just feels like an old v8 dog and does not want to rev at all while under load. I also just noticed that my vtec engages even tho i dont have a oil pressure sensor, so does that mean my ecu is chipped??? if so it could be my ecu then right???
Old Jul 18, 2006 | 10:47 PM
y-49's Avatar
i would say replace the coil cause they tend to act up after getting hot
Old Jul 18, 2006 | 10:53 PM
charlee's Avatar
Default Re: (teler86)
well.IMO if it smells like gas then its not ur ecu. i would go withthe fuel preassure regulator. idk. what do you think?
EDIT.. also check ur spark plugs to see if there is anysigns of it running to rich.
Old Jul 19, 2006 | 07:55 AM
teler86's Avatar
i will change the coil that sounds like a good idea, will the one off of a 99si work??? also does the stock fuel pressure regulator go bad?
Old Jul 19, 2006 | 08:48 AM
d16vtecx's Avatar
02 sensor going bad?
Old Jul 19, 2006 | 12:17 PM
Contender25
Guest
Posts: n/a
Well they do say if it's running rich or really rich then you can actually lose power i believe, correct me if im wrong.
Old Jul 20, 2006 | 06:06 AM
teler86's Avatar
well yes but the car does not want to rev at all past 3k after it's hot, once it cools down it is perfectly fine, the o2 is brand new as of last month I am really leaning towards the coil, how do i change it is it right behind the distributor cap
Old Jul 20, 2006 | 11:43 AM
Contender25
Guest
Posts: n/a
O thats easy bro, just take off the dizzy cap and it should be right on top, looks like a black square pack basically, a coil pack, lol and should be 4 tiny little screws holding it on, take them off carefully without losing them to take the coil pack out and your done.
Old Jul 20, 2006 | 02:41 PM
MatchBox Racer's Avatar
My b16 boggs like crazy right away and its constant people tell me that it is my throttle angle sensor you could try adjusting it
Phillip Jones
14
Nov 16, 2017 07:17 PM
simplypinoyy
Jul 29, 2008 05:53 AM
DC4 me
Dec 9, 2006 10:07 PM
eg_civic209
Dec 1, 2006 06:11 AM
ImportPower13
Apr 23, 2005 12:36 PM
