My 1/4 mile times.
Old Jul 15, 2006 | 12:55 AM
realis9's Avatar
Default My 1/4 mile times.
street tires. Dunlop fm 901. Tire pressure 40psi
First run" 60" 2.253 2. run: 2.635 last run: 2.396
1/8 9.194 , 9.659 , 9.261
mph 80.24 , 80 , 80.93
1/4 14.131 , 14.5 , 14.156
mph 100.14, 100.18 , 100.77
Only had the drivers seat in.
Old Jul 15, 2006 | 06:21 AM
mugenracer's Avatar
nice times! What mods?
Old Jul 15, 2006 | 07:21 AM
typerman's Avatar
Default Re: (mugenracer)
should have lowered your tire pressure might have helped you get some better 60 ft times nice time though
Old Jul 15, 2006 | 08:41 AM
RGoose18's Avatar
Default Re: (typerman)
what'd mods?
Old Jul 15, 2006 | 09:06 AM
typer1982's Avatar
Default Re: (RGoose18)
wat r ur mods??
Old Jul 15, 2006 | 10:10 AM
Dat1BVtecN's Avatar
Default Re: (typer1982)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer1982 &raquo;</TD></TR><TR><TD CLASS="quote">wat r ur mods??</TD></TR></TABLE>
Old Jul 15, 2006 | 10:18 AM
typer_696's Avatar
Default Re: (Dat1BVtecN)
His mods were listed on his dyno pull previously.
Old Jul 15, 2006 | 10:20 AM
hybrider's Avatar
Default Re: (typer_696)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_696 &raquo;</TD></TR><TR><TD CLASS="quote">His mods were listed on his dyno pull previously.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1672389
Old Jul 15, 2006 | 01:53 PM
realis9's Avatar
Default Re: (hybrider)
yeah i know the stock tire was too high. Next time though i will lower the tire pressure. i only got two runs . I'm going for 13's.
Old Jul 15, 2006 | 03:44 PM
B7AudiA4's Avatar
Default Re: My 1/4 mile times. (realis9)
you can hit 13s.. shouldn't be too much trouble.
Old Jul 15, 2006 | 06:22 PM
ITR#00-1077's Avatar
Great times, but still no mod list.... please do tell...
Old Jul 15, 2006 | 06:34 PM
Dave_B's Avatar
With the mods you have, you should be seeing 13.8's or better. Like someone mentioned, you need to drop the tire pressure down to say around 20 PSI. When I ran mine, I had it down to like 18.5, but you will want to start higher than that and work your way down. Also not mentioned, what RPM where you launching at? Any wheel spin? 60's look pretty good but you could get them a little bit better. What your looking for is 2.2-2.0's. With 100 MPH trap speeds, you can get into the 13's. Just keep practicing and have fun.
Old Jul 15, 2006 | 06:46 PM
realis9's Avatar
Default Re: (Dave_B)
i was launching at 4 to 4.5 rpm feathering the clutch. Any higher and i would have gotten too much wheel spin. The 2.6 60" was launching above 5000 rpm. I should of lowered the tire pressure. I was running 40 psi. I should be going again soon. I would like to run drag radials, but i don't want to damage my tranny or axles. I HATE that first to second gear change. It feels like the tranny is going to break.
Old Jul 15, 2006 | 06:50 PM
Dave_B's Avatar
You'll be ok. What the goal is, is to never come out of Vtec. If you can lauch at say 5500, with a little less air pressure, I think you'd be ok with the wheel spin. Yes, you do have to slip the clutch quite a bit to get it to work right, but the first time you get it right you'll know. It will feel like a freight train coming out of the hole instead of falling on it's face, and then going back into Vtec. The key is practice. This was the first time out with the new setup. Keep going and keep us updated about the the results.
Old Jul 15, 2006 | 06:52 PM
realis9's Avatar
Default Re: (realis9)
Anything over 4.5 rpm i get too much wheel spin. 2.2 and 2.3 60" was launching 4.5 rpm.
Old Jul 15, 2006 | 06:53 PM
Dave_B's Avatar
You just need to lower the tire pressure. Once you get that lower, the wheel spin will be less of an issue. If anything, you'll start to get wheel hop instead of spin.
Old Jul 15, 2006 | 06:54 PM
realis9's Avatar
i will have new times next month. Dave is it really bad on the tranny and axles throwing into second gear that hard?
Old Jul 15, 2006 | 06:56 PM
Dave_B's Avatar
Well it is worse than say "going easy" but when I dragged my R, I was shifting pretty hard. It would bark the tires between 1-2 shift and 2-3 shift. Sometimes I'd even get a little bit of spin between the 1-2 shift. Is it going to cause your trans to fall out though, no.
Old Jul 15, 2006 | 06:57 PM
realis9's Avatar
cool
Old Jul 16, 2006 | 05:02 AM
BoBo Racing's Avatar
good times bro just keep practing that launch ull be in the 13s in no time
Old Jul 16, 2006 | 07:08 AM
totsie7944's Avatar
I find that wheel hop is way worse than wheel spin at 20psi....
Usually I really have to watch the gas until I get a grip then let it rip... haha
Old Jul 16, 2006 | 11:19 AM
mtber's Avatar
Default Re: (totsie7944)
100 mph trap speeds = 13s
Old Jul 16, 2006 | 12:04 PM
RTW DC2R's Avatar
crappy 60ft, but nice trap.
dont "launch". youll have much better results with lower tire pressure and preloading.
Old Jul 16, 2006 | 12:13 PM
realis9's Avatar
Default Re: (RTW DC2R)
i was really pleased with the trap speed. I cannot wait to go again next month. I will get that 13 sec run
Old Jul 16, 2006 | 12:36 PM
cambopheonix56's Avatar
Nice.
realis9
Jul 17, 2005 08:33 AM
PA MATT
Aug 20, 2004 08:10 PM
jdmjeff
Feb 11, 2004 07:58 PM
b18c195
Sep 22, 2003 06:23 AM
FusionEg6
Aug 19, 2003 06:57 PM
