HELP single cam f22 into my 91 hatch
Old Jul 14, 2006 | 11:10 PM
I B BANGGIN's Avatar
Default HELP single cam f22 into my 91 hatch
i have a 2000 f22 longblock and 90 accord tranny i need some info on what else i need? can i use stock mounts and what shift linkage do i have to use? any info would help. planning to use a cheaped p28. hopfully this would be kinda easy to do
Old Jul 14, 2006 | 11:14 PM
QuarterMileMaster's Avatar
Default Re: HELP single cam f22 into my 91 hatch (I B BANGGIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I B BANGGIN &raquo;</TD></TR><TR><TD CLASS="quote">i have a 2000 f22 longblock and 90 accord tranny i need some info on what else i need? can i use stock mounts and what shift linkage do i have to use? any info would help. planning to use a cheaped p28. hopfully this would be kinda easy to do </TD></TR></TABLE>
Hey, I (carguy) see you on h-i alot, welcome. Anyways, from what I've heard the swap isn't exactly easy. You can use an h-series into ef mounts I believe. Wiring should be quite interesting. What made you decide to do this swap, not alot of aftermarket support and really not that great of a motor. Just my .02 but if you want to give it a shot go for it! Anyways, it'd also be cool if you could get the H-D tranny conversion plate so you could use a d-series tranny. Hooking up a zc tranny to that torquey motor would be sick...
Old Jul 14, 2006 | 11:28 PM
im just trying to do somthing diffrent i was hoping itll be easy...i really want to do it...i just want more info of what im getting into so if anyone can help or give me more info i would apreciate it..im kinda on a budget to
Old Jul 14, 2006 | 11:32 PM
d16vtecx's Avatar
Default Re: (I B BANGGIN)
you need an H into ef mount kit
obd-0 to obd1 conversion harness
probably need custom shift linkage, throttle cable
there is a lot more that i can't remember
if you search there is tons of info
Old Jul 15, 2006 | 04:29 AM
Sikocivic's Avatar
Its been done before. I would use the adapter plate for the D-series tranny, solves alot of problems.
http://www.bisimoto.com/wst_page10.html
CTCD5
K Series
Dec 13, 2013 05:43 AM
ShockerhatcH
Mar 2, 2009 01:02 PM
kcjohnnyboy
Feb 23, 2006 10:50 PM
streetspeed607
Apr 10, 2004 03:37 PM
infamousALLMTR
May 3, 2002 12:57 PM
