ZC Doch vs. Soch Vtec
so im looking to drop a nice little cheap peppy swap on my 90 dx crx...i was think either a doch zc or soch vtec which cost about the same n labor on swap costs about the same....which motor do you guys think would be a better choice?
Doch? Double Over Cam Heads? Theres 2 heads for every cam?
Or did you mean DOHC? lol.
Seriously, though, I'd go with the DOHC ZC cause 2 cams are always better than 1
i have personaly had 2 dif. crx's with both motors u are talkin about...
1. 89 crx SI with state reffed d16z6 with I/H/E
2. 88 crx si (currently have) with DOHC ZC i/h/e/under drive pully/fuel rail
i took the zc to the track and it ran a 15 flat, i never ran the d16z6 motor but i would say that motor felt about the same as the zc.... so either way ur going to get a nice power dif. from ur stock motor.. i would say if u wana do many mods go SOHC v-tec cuz parts are cheap/easier to get.. dohc zc's u have to find parts like cams and **** and its exspensive... but i gota say i love my zc.. i have had NO problems with it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Just_Call_Me_Cheddarbek »</TD></TR><TR><TD CLASS="quote">Doch? Double Over Cam Heads? Theres 2 heads for every cam?
oh yea, its almost 3am in jersey, im not exactly on top of my typing skills right now but u know what i meant..
</TD></TR></TABLE>oh yea, its almost 3am in jersey, im not exactly on top of my typing skills right now but u know what i meant..
i currently have a z6 in a crx
i drove a dohc zc crx about a year ago and i would say the z6 had better topend
and the dohc zc had slightly better low end
the dohc zc is easier to wire up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16vtecx »</TD></TR><TR><TD CLASS="quote">i currently have a z6 in a crx
the dohc zc is easier to wire up</TD></TR></TABLE>
ya cuz there straight bolt ins only thing u have to change is ur dizzy wiring (get the jumper from rywire) and u have to wire the cam angle sensor (2 wires)and u also have to get a integra upper rad. hose
"two cams are better at sucking dick than one"
whats this horeshit? if you want a CHEAP upgrade, get the zc.
if yoiu want a ton of aftermarket parts and support, get the Z6, and its just as easy to drop in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueRex1020 »</TD></TR><TR><TD CLASS="quote">so im looking to drop a nice little cheap peppy swap on my 90 dx crx...i was think either a doch zc or soch vtec which cost about the same n labor on swap costs about the same....which motor do you guys think would be a better choice?</TD></TR></TABLE>
Depends on whether you are willing to do the SOHC VTEC swap properly or not. If you refuse to convert to OBD-1, then you're better off with the DOHC ZC. If you are willing to do an OBD-1 conversion without halfassing it, then go ahead and do the SOHC VTEC swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crexster »</TD></TR><TR><TD CLASS="quote">i would do the sohc with the zc pistons and call it a day... with that setup the put down the same numbers as a stock b16
(just under 150whp)</TD></TR></TABLE>
Umm . . . a stock B16A doesn't put down anywhere near 150whp, and neither does a D16Z6 with just DOHC ZC pistons.
(just under 150whp)</TD></TR></TABLE>Umm . . . a stock B16A doesn't put down anywhere near 150whp, and neither does a D16Z6 with just DOHC ZC pistons.
(just under 150whp)</TD></TR></TABLE>What the, Not even 150 fwhp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Depends on whether you are willing to do the SOHC VTEC swap properly or not. If you refuse to convert to OBD-1, then you're better off with the DOHC ZC. If you are willing to do an OBD-1 conversion without halfassing it, then go ahead and do the SOHC VTEC swap.</TD></TR></TABLE>
[literal question]How are 2 cams better than one?[/literal question]
Have you ever stopped to think about these type of regurgitated statements? If I can get 1 piece of spinning metal to do what 2 pieces of spinning metal to do, I gain efficiency, all else being equal, through the loss of friction and rotating weight. The design of the sohc is pretty clever...
The dohc zc has a lack of aftermarket support. Cams, as I understand it, are limiter to regrinds and ol-skool hks pieces, which weren't spectacular to begin with. availability of replacement parts should be a factor as well. Let's say, you blow a head gasket on a top-speed run... you take the head to the local machinist, and mill the head flat. let's say the head is warped out of spec. you'll need to search much harder for a replacement than you would otherwise. plus, the head you end up getting is older and typically has more miles than it's counterpart. the z6 heads are PLENTIFUL! Good luck on whatever you chose, and let us know how it goes!
-josh-
-josh-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Umm . . . a stock B16A doesn't put down anywhere near 150whp, and neither does a D16Z6 with just DOHC ZC pistons.</TD></TR></TABLE>
with intake header and exhaust and tuned they do
also you could do the sohc swap w/ zc pistons and tune it with BRE on an obd0 pr3 ecu and def get just under 150WHP dont listen to them ive seen it
FastAzzDA
Oct 23, 2006 07:57 AM
