HELP! cali. smog
HC means excessive unburned fuel or misfire it is usually the spark plugs, wires, cap and rotor. What is your CO and NOX levels? maybe I can see what kind of problem you have by seen the other numbers. OOO also a lack of fuel will cause the HC to go hi but you would have hi NOX and very low CO because it will be considered a lean mixture.
roldan1986
10
Mar 15, 2016 12:52 PM
LAO
Jul 28, 2008 07:00 AM
