ecu help plz
whats it the ecu for the 99 prelude (stick) and does anyone know where to buy it pretty cheap? i looked in faqs did not find anything everytime i search online will not say it for the 99 lude base model usdm
http://www.slhondaparts.com to find the right part number and price at dealer.
Junkyard or classifieds to buy it used, then I would assume take it to the dealer for the immobilizer stuff.
Yea, P5M. Be careful not to get 97-98 ecu and run in 99-01 car. I forgot what the problem, but basically you can't start the car everytime you fill the gas. Trust me, I ran with 97 ecu in my 99 car before, and I could not figure out wth wrong until somebody posted in here. Try ebay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrLude1 »</TD></TR><TR><TD CLASS="quote">You mean a USDM P13 OBDII (M/T)?</TD></TR></TABLE>
No, that is a '96 ECU.
He needs a P5M, from a '99 model year. '97 and '98 ECUs lack proper emissions controls for '99+ and the car will choke on startup after you fill the fuel tank.
well i heard about that but i cant find one 99 and up i find 98-01 but will that still not work? im jus curious because im doing an a to m conversion and i am chipn my ecu to 5speed but someone told me hondata will not work with chipd ecus is that correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxx99ludexxx »</TD></TR><TR><TD CLASS="quote">well i heard about that but i cant find one 99 and up i find 98-01 but will that still not work? im jus curious because im doing an a to m conversion and i am chipn my ecu to 5speed but someone told me hondata will not work with chipd ecus is that correct?</TD></TR></TABLE>
If you already have an auto P5M, just convert it to manual. Hondata won't work on a P5M anyway. You would need a OBD-1 P72 for that.
not a p13? i fund a wiren harnest for obd2 to obd1 i asked a friend today if would be able to do that cause i jus found out about hondata being for obd1 blah blah
k question is can i run an obd1 ecu witha obd2 engine with the h22a4?
fishboy
Nov 3, 2008 03:42 PM
fasttypeR
May 3, 2002 05:35 AM
