Help w/ axels
Old Jul 14, 2006 | 04:13 PM
bboyPHOENIX's Avatar
Default Help w/ axels
b16a sir j1 transmission. in a (91 Crx Si)
What axels can I buy (make, model, type) that will work right?
I used the SSEARCH but it was too vague. Not enough info and everyones tryin to be a smart ***. Thanks!
Oh and it's a cabel transmission
Old Jul 14, 2006 | 04:39 PM
crxpwr1's Avatar
Default Re: Help w/ axels (bboyPHOENIX)
90-93 integra axles not abs
Old Jul 14, 2006 | 04:54 PM
crxpwr1's Avatar
Default Re: Help w/ axels (crxpwr1)
not to thread jack but what if I get the b16 swap with s1 tranny can I still use the 90-93 integra axles??
Old Jul 14, 2006 | 05:02 PM
Loserkidwac's Avatar
the real determining factor for the axles is the mid shaft...all b series axles will work with B series trannies with either the 90-93 mid shaft or the 94+ mid shaft...
If you use a cable tranny with a 94+ mid shaft you can run 94+ axles but you need to replace the axles seal in the tranny 94+ is begger I believ and vise versa if you want to run a hyro tranny with the 90-93 axles
RunninEg6
Feb 15, 2009 09:38 PM
civiconfire
Feb 27, 2007 07:29 PM
Si-Yaaa!
May 10, 2003 05:02 PM
mrcivichybrid
Nov 22, 2002 11:53 AM
Suprdave
Aug 12, 2001 12:19 PM
