GSR engine swap help
i am planning to buy an integra with a GSR swap. the guy says its from a 99 GSR....
can anyone tell me what should i look for when i look under the hood/ecu wise to make sure everything is LEGIT?
thanks
thanks
look at the head stamp on the front left for the year and casting. it should say 98 and p-72. (year made and casting for a GSR head). also look at the block on the bottom left for b18c1 and the vin in the bottom middle right above the oil pan
good luck
good luck
VIN# are the most important and check the head, and check for yourself if it is a 99...Make sure you get the billing statement from when he bought that engine. and make sure that VIN# match...Unless the car has been BAR'd then you should have a sticker on the firewall with that informtion already...
2000dollarzcbs
Nov 28, 2005 10:51 PM
vtec00
Apr 6, 2005 06:47 AM
